Extracting the XYZ coordinates of the elements from Revit through Dynamo
aagr657
aagr657
Hii,
I am trying to export the coordinates of piles from a Revit model using a Dynamo script. I am trying to use the family instance location. However, the warning I am getting over the FamilyInstance.Location node is 'Warning: FamilyInstance.Location expects argument type(s) (Revit.Elements.FamilyInstance), but was called with (Revit.Elements.DirectShape[]).'
Now, looking at the properties of the piles in Revit, I figured out that the family of the piles is 'Direct Shape', probably that's the reason Dynamo isn't working.
Is there any way to extract the coordinates of such elements?
sayu94
Hi. If you want to use this node in Dynamo - you must use simple Families, that you did manually by template family on level. After that - all will be work))
aagr657
Hii,
Many thanks for your response.
The model actually is not prepared by me. I got it in .ifc format and when I imported it in Revit, the family type of the piles is direct shape. Is there any way I can change the family to something like a column?
Best Regards,
Ajay
sayu94
if you want use actually this direct dhape families- you must analyze geometry. I think you can get center of solid element and get most top point. After that you can get x,y coordinate from center solid and z from top point
SAINA02
Hi
You can use "Element.Location+" node form "Clockwork" package for this purpose.
You should also pay attention to points highlighted in link below about the coordinate system used for determining the element location:
https://www.linkedin.com/pulse/getting-coordinates-dynamo-jason-murray
Good Luck
ederbel
extracting the X Y Z geographic coordinates of the elements in REVIT based on the base point and the topographic point (it's more exact)
