Automatically fill parameters when the file is updated
mat_hijs
mat_hijs
I have some Revit projects that are exports from Inventor. I also have a dynamo script that checks if certain shared parameters exist in the project, if they don't exist, it adds them, if they do exist it fills their values based on the type names of the family instances. All these models are grouped in a separate folder and are all linked within my main Revit project.
Right now I need to run this every time I updated the export from Inventor to make sure all the values are up to date. I'm looking for a way to do this automatically when the export is updated.
My first thought was somehow running the dynamo script automatically but I haven't found a way to do this. My second thought was somehow running a macro on a specific event but I wouldn't know what event could be used. Also, I'm not familiar with the Revit API so that would be a challenge.
Anyone has any idea's how to accomplish this?
jeremy_tammik
You could use the DocumentOpened event to trigger running your script automatically each time a document is opened:
https://www.revitapidocs.com/2023/7e5bc7a1-0475-b2ec-0aec-c410015737fe.htm
mat_hijs
@jeremy_tammik Will this event trigger a macro in the linked model when the main model is opened or would the file have to be actually opened manually? If it will be triggered, will this cause problems because there might be 10 models that are triggered to run a macro at the same time?
