extract material from ReferenceWithContext
c_hanschen
c_hanschen
Short Story:
How can I find the material of the face found by ReferenceIntersector..??
Long Story:
I'm using a ray (ReferenceIntersector) to find intersecting elements, this works out great!
It returned a 'List(Of ReferenceWithContext)' that provides me information of intersection (.GetReference.GlobalPoint) and element (.GetReference.ElementId)
Even thru I used the .TargetType = FindReferenceTarget.Face, it's returns the ElementId's of the Revit elements, not the face.
An element (by example a Window) can contain many faces.
This is one of the things I tryed: (type conversion from reference to face, because a face has a material)
If MyReferenceWithContext.GetReference.ElementReferenceType = ElementReferenceType.REFERENCE_TYPE_SURFACE Then
  Dim MyFace As Face = TryCast(MyReferenceWithContext.GetReference, Face)
  MsgBox(MyFace.MaterialElementId.IntegerValue.ToString)
End If
Chris Hanschen
The Netherlands
FAIR59
You get the face from the Element using the GetGeometryObjectFromReference method.
            ReferenceWithContext context
            Element el = doc.GetElement(context.GetReference().ElementId);
            GeometryObject geoObj = el.GetGeometryObjectFromReference(context.GetReference());
                Face _face = geoObj as Face;
                if (_face != null) TaskDialog.Show("debug", doc.GetElement( _face.MaterialElementId).Name);
Revitalizer
Hi FAIR59,
the face may be part of an element inside a linked document,
so its material may not exist in the main document but in the linked one.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
c_hanschen
Thanks a lot...!!
I will try this later this week, but this seems to be what I am looking for..!!!
Chris
The Netherlands
c_hanschen
Hello!
New question similar te the one in this topic.
Getting ReferenceWithContext by Ray is on of the most powerful functions in the Revit API, for me it is #1!
In de Aanswers in this Topic we can read how te get the Face and the Material of the Face.
Is there a way to get the (name of) the Subcategory of this Face?
Thanks!
Chris Hanschen
LKSVDD architecten
The Netherlands
RPTHOMAS108
You can get from the GraphicsStyleId if a subcategory is set for the solid in the family.
c_hanschen
New Question about getting info from ReferenceWithContext, in this topic we found .Face and .Material, but how to get the .Transform of/for the .Face ?
Thanks in Advance,
Chris Hanschen
LKSVDD architecten
The Netherlands
