Controlling size of flex as it is created with API
mhillis
mhillis
Hello all,
I'm running into a minor issue while creating flex with the API.
You see - I am currently using the following API routine to create Flex Duct.
Autodesk.Revit.Creation.Document.NewFlexDuct(connector1, connector2, flexTypeId);
So far, this has been the most consistent method of putting together flex.  I have not had much luck putting together a system that builds flex well with points, so I've opted for using the connector method.
The issue I am having is that I cannot control the size of the flex as it comes in, so when I call this method it will automatically connect to my connectors which on its own is fine.  The problem is that, since I cannot control the size, I'm getting transition/reducers everywhere because Revit wants to put those down since I am, in essence, trying to connect a 12" flex to another size (12" being the default it seems).
So, does anyone know a way to work around this issue so I can stop having Revit dump a bunch of reducers/transitions on my connectors?
Thanks!
FAIR59
Solution: change the  diameter of the flexduct in the same transaction:
                Autodesk.Revit.DB.Mechanical.FlexDuct f = doc.Create.NewFlexDuct(connector0, connector1, ducttype);
                f.get_Parameter( BuiltInParameter.RBS_CURVE_DIAMETER_PARAM).Set(ductsize);
JimJia
Yes, I also think changing the flex's parameter after creation is the applicable approach; There is no other method to control the size during flex create.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
mhillis
JimJia,
I am aware of this, but this does not deal with the issue as I described in my inital post.  If you use the CreateFlex routine that accepts connectors for it's parameters, the routine itself will connect to those connectors with a default flex size (10" I believe).  When this connection happens within the creation routine, it will either drastically change the fittings or it will drop transitions to make the fittings work.  All of this happens before I have the opportunity to change the size of the flex.  I can change the flex after the fact yes, but the damage is already done.  I'd like to prevent these things from happening in the first place.
