External Command-Document are temporary disabled
markjvlampad
markjvlampad
Does anybody experience this kind of external command error?
how did you sort this out?
when I use this in macro it works perfectly. but when I use external command, I get the error.
using (Transaction t = new Transaction(doc,"Create ViewSet"))
t.Start();
string setName = "SheetSet Name";
try
viewSheetSetting.SaveAs(setName);
catch (Autodesk.Revit.Exceptions.InvalidOperationException)
TaskDialog.Show("Error", setName + " is already in use");
t.RollBack();
return;
t.Commit();
jeremytammik
Maybe you have set read-only transaction mode. Maybe your document is read-only. Maybe some other command is blocking something. Can you modify your document manually through the user interface?
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
