Seemingly quite a simple one, so I can't see what is going wrong...!
I have a button to execute, I'm on Revit 2021...
public bool IsCommandAvailable(UIApplication app, CategorySet cate)
// zero doc state
if (app.ActiveUIDocument == null)
// disable register btn
return true;
// enable register btn
return false;
For some reason, this is returning true, despite the ActiveDocument obviously not being null!
Any assistance gratefully received,
Full code below...
Mark
using System;
using System.IO;
using System.Reflection;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.Attributes;
namespace RevitAddInsWPFSample
// external application class
[Transaction(TransactionMode.Manual)]
public class MainClass : IExternalApplication
// execute when application open
public Result OnStartup(UIControlledApplication application)
// create a ribbon panel
RibbonPanel ribbonPanel = application.CreateRibbonPanel(Tab.AddIns, "TwentyTwo Sample");
// assembly
Assembly assembly = Assembly.GetExecutingAssembly();
// assembly path
string assemblyPath = assembly.Location;
// Create Register Button
PushButton registerButton = ribbonPanel.AddItem(new PushButtonData("Register Window", "Register",
assemblyPath, "RevitAddInsWPFSample.Register")) as PushButton;
// accessibility check for register Button
registerButton.AvailabilityClassName = "RevitAddInsWPFSample.CommandAvailability";
// btn tooltip
registerButton.ToolTip = "Register dockable window at the zero document state.";
// register button icon images
registerButton.LargeImage = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.register32.png");
registerButton.Image = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.register16.png");
// Create Show Button
PushButton showButton = ribbonPanel.AddItem(new PushButtonData("Show Window", "Show", assemblyPath,
"RevitAddInsWPFSample.Show")) as PushButton;
// btn tooltip
showButton.ToolTip = "Show the registered dockable window.";
// show button icon images
showButton.LargeImage = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.show32.png");
showButton.Image = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.show16.png");
// return status
return Result.Succeeded;
// execute when application close
public Result OnShutdown(UIControlledApplication application)
// return status
// get embedded images from assembly resources
public ImageSource GetResourceImage(Assembly assembly, string imageName)
try
// bitmap stream to construct bitmap frame
Stream resource = assembly.GetManifestResourceStream(imageName);
// return image data
return BitmapFrame.Create(resource);
catch
return null;
// external command availability
public class CommandAvailability : IExternalCommandAvailability
// interface member method
// zero doc state
return true;
return false;
// external command class
public class Register : IExternalCommand
Viewer dockableWindow = null;
ExternalCommandData edata = null;
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
// dockable window
Viewer dock = new Viewer();
dockableWindow = dock;
edata = commandData;
// create a new dockable pane id
DockablePaneId id = new DockablePaneId(new Guid("{68D44FAC-CF09-46B2-9544-D5A3F809373C}"));
try
// register dockable pane
commandData.Application.RegisterDockablePane(id, "TwentyTwo Dockable Sample",
dockableWindow as IDockablePaneProvider);
TaskDialog.Show("Info Message", "Dockable window have registered!");
// subscribe document opened event
commandData.Application.Application.DocumentOpened += new EventHandler<Autodesk.Revit.DB.Events.DocumentOpenedEventArgs>(Application_DocumentOpened);
// subscribe view activated event
commandData.Application.ViewActivated += new EventHandler<ViewActivatedEventArgs>(Application_ViewActivated);
catch(Exception ex)
// show error info dialog
TaskDialog.Show("Info Message", ex.Message);
// return result
// view activated event
public void Application_ViewActivated(object sender, ViewActivatedEventArgs e)
// provide ExternalCommandData object to dockable page
dockableWindow.CustomInitiator(edata);
// document opened event
private void Application_DocumentOpened(object sender, Autodesk.Revit.DB.Events.DocumentOpenedEventArgs e)
public class Show : IExternalCommand
try
// dockable window id
DockablePane dockableWindow = commandData.Application.GetDockablePane(id);
dockableWindow.Show();
catch(Exception ex)
// return result
