External Command Availability
Mark.Ackerley
Mark.Ackerley
Seemingly quite a simple one, so I can't see what is going wrong...!
I have a button to execute, I'm on Revit 2021...
public bool IsCommandAvailable(UIApplication app, CategorySet cate)
            // zero doc state
            if (app.ActiveUIDocument == null)
                // disable register btn
                return true;
            // enable register btn
            return false;
For some reason, this is returning  true, despite the ActiveDocument obviously not being null!
Any assistance gratefully received,
Full code below...
Mark
using System;
using System.IO;
using System.Reflection;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.Attributes;
namespace RevitAddInsWPFSample
    // external application class
    [Transaction(TransactionMode.Manual)]
    public class MainClass : IExternalApplication
        // execute when application open
        public Result OnStartup(UIControlledApplication application)
            // create a ribbon panel
            RibbonPanel ribbonPanel = application.CreateRibbonPanel(Tab.AddIns, "TwentyTwo Sample");
            // assembly
            Assembly assembly = Assembly.GetExecutingAssembly();
            // assembly path
            string assemblyPath = assembly.Location;
            // Create Register Button
            PushButton registerButton = ribbonPanel.AddItem(new PushButtonData("Register Window", "Register",
                assemblyPath, "RevitAddInsWPFSample.Register")) as PushButton;
            // accessibility check for register Button
            registerButton.AvailabilityClassName = "RevitAddInsWPFSample.CommandAvailability";
            // btn tooltip
            registerButton.ToolTip = "Register dockable window at the zero document state.";
            // register button icon images
            registerButton.LargeImage = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.register32.png");
            registerButton.Image = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.register16.png");
            // Create Show Button
            PushButton showButton = ribbonPanel.AddItem(new PushButtonData("Show Window", "Show", assemblyPath,
                "RevitAddInsWPFSample.Show")) as PushButton;
            // btn tooltip
            showButton.ToolTip = "Show the registered dockable window.";
            // show button icon images
            showButton.LargeImage = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.show32.png");
            showButton.Image = GetResourceImage(assembly, "RevitAddInsWPFSample.Resources.show16.png");
            // return status
            return Result.Succeeded;
        // execute when application close
        public Result OnShutdown(UIControlledApplication application)
            // return status
        // get embedded images from assembly resources
        public ImageSource GetResourceImage(Assembly assembly, string imageName)
            try
                // bitmap stream to construct bitmap frame
                Stream resource = assembly.GetManifestResourceStream(imageName);
                // return image data
                return BitmapFrame.Create(resource);
            catch
                return null;
    // external command availability
    public class CommandAvailability : IExternalCommandAvailability
        // interface member method
            // zero doc state
                return true;
            return false;
    // external command class
    public class Register : IExternalCommand
        Viewer dockableWindow = null;
        ExternalCommandData edata = null;
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            // dockable window
            Viewer dock = new Viewer();
            dockableWindow = dock;
            edata = commandData;
            // create a new dockable pane id
            DockablePaneId id = new DockablePaneId(new Guid("{68D44FAC-CF09-46B2-9544-D5A3F809373C}"));
            try
                // register dockable pane
                commandData.Application.RegisterDockablePane(id, "TwentyTwo Dockable Sample",
                        dockableWindow as IDockablePaneProvider);
                TaskDialog.Show("Info Message", "Dockable window have registered!");
                // subscribe document opened event
                commandData.Application.Application.DocumentOpened += new EventHandler<Autodesk.Revit.DB.Events.DocumentOpenedEventArgs>(Application_DocumentOpened);
                // subscribe view activated event
                commandData.Application.ViewActivated += new EventHandler<ViewActivatedEventArgs>(Application_ViewActivated);
            catch(Exception ex)
                // show error info dialog
                TaskDialog.Show("Info Message", ex.Message);
            // return result
        // view activated event
        public void Application_ViewActivated(object sender, ViewActivatedEventArgs e)
            // provide ExternalCommandData object to dockable page
            dockableWindow.CustomInitiator(edata);
        // document opened event
        private void Application_DocumentOpened(object sender, Autodesk.Revit.DB.Events.DocumentOpenedEventArgs e)
    public class Show : IExternalCommand
            try
                // dockable window id
                DockablePane dockableWindow = commandData.Application.GetDockablePane(id);
                dockableWindow.Show();
            catch(Exception ex)
            // return result
RPTHOMAS108
That looks like it is back to front i.e. you return false if you want to disable the command button and true to enable it.
Mark.Ackerley
Hey,
Thanks for the reply... Here's a screen grab from Jeremy's example... It's seems to be the same? I played with flipping it, but though I can get it to run without error, the window doesn't initialise...
Thanks again,
Mark
Mark.Ackerley
I tried using the sample from Jeremy's github and swapping the true false to let me click the register button...
I hit register and nothing appears to happen... then i click Show and am told that the requested dock pane has not been created yet...
If I click around the screen, I get the buttons to stop being greyed out... Then I click Register again... I get 'cannot register the same dockable pane ID more than once...!
Any thoughts greatly appreciated 🙂
Mark
RPTHOMAS108
Ok from how I understand it on the tooltip the sample intends you to Register the dockable window in the zero document state so the CommandAvailability was ok as it was. The register button should only be available when you have no documents open (this is the opposite of what you generally want for other commands).
Ordinarily I would be registering the window during OnStartUp of IExternalApplication.
https://forums.autodesk.com/t5/revit-api-forum/adding-properties-to-dockable-pane/m-p/9522502/highli...
Mark.Ackerley
Ahah...!
Obvs 🙂
Thanks for the help!
