Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Exporting/Printing schedule containing image
4 REPLIES 4
programmer59
1744 Views, 4 Replies
When I create a schedule with images (for exemple rebar with the image of the shape)
I would like to :
export it in Excel (with the image)
print the table in a pdf file (with the image too)
Is it possible ? How to do this?
The only think I know, is to copy/paste the view (Schedule) on a sheet in Revit, but it is not handy.
Concerning this topic, I would like to do this manually, and with lines codes in C++ API.
Best Regards,
CIvil Engineer
4 REPLIES 4
jeremytammik
in reply to: programmer59
You can access the schedule data and the images it contains programmatically, e.g., using the Revit Schedule API:
http://thebuildingcoder.typepad.com/blog/2012/05/the-schedule-api-and-access-to-schedule-data.html
Then, you can use that data and the Excel programming interface to generate a spreadsheet from that.
You can use other programming libraries to generate a PDF from the same data.
Please consult Excel and PDF-specific programming documentation for those tasks, since they have nothing to do with the Revit API.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
programmer59
Hi Jeremy
Thanks a lot for your answer. I've not tried yet your solution, but I will try.
I've seen the link you sent. When exporting the schedule, it does that to a text file with separation. So, how could it work with images in the data base of the schedule?
programmer59
in reply to: jeremytammik
Hi
I have tried the following code :
/*FilteredElementCollector col
    = new FilteredElementCollector( doc )
      .OfClass( typeof( ViewSchedule ) );
  ViewScheduleExportOptions opt
    = new ViewScheduleExportOptions();
  foreach( ViewSchedule vs in col )
    Directory.CreateDirectory(
      _export_folder_name );
    vs.Export( _export_folder_name,
      vs.Name + _ext, opt );
It works only for data containing text and numbers. But when the schedule contains a image, it only export the name of the image (see my export test in the screencast below)
jeremytammik
So, you can implement the next step: from the name of the image, navigate to the image itself and  include the required information into your output in the desired manner, for instance by adding a graphical representation of the image.
Jeremy Tammik
The Building Coder
Rail Community
