Message 1 of 9
Export the sheet to pdf and suppress the dialog to save the file location
04:19 AM
Hello all,
I'm trying to export sheet in PDF format by using @jeremytammik solution (link here). So far the solution is perfect. However, whenever I try to export the sheet a dialog box appears to choose the location to save. I was wondering Is it possible to override the print driver settings, without a dialog popping up? I want to automatically choose the locations, rather than clicking it in the file system each time.
Here's the code:
public static void ExportSheetToPDF(Document doc, string path)
using (Transaction tx = new Transaction(doc))
tx.Start("Exportint to PDF");
PrintManager pm = doc.PrintManager;
pm.SelectNewPrintDriver("Adobe PDF");
pm.PrintRange = PrintRange.Current;
pm.CombinedFile = true;
pm.PrintToFile = true;
pm.PrintToFileName = path + @"\PDF\" + "test.pdf";
pm.SubmitPrint();
tx.Commit();
Update:
Also, I don't want to change the 'Printing Preferences' setting because in that case dialog will be suppressed but the location where the pdf will be saved get hard coded. I would like to provide the filepath value from code dynamically.
Developer Advocacy and Support +
