How to Export View/Sheet set to PDF DWG and DWF format
Message 1 of 8
Hello all,
I'm developing an add-in that will export selected view/sheet set into PDF, DWG and DWF file format. I'd like to know how can I achieve this functionality through revit API. Appreciate any suggestion or hint.
Ali
Replies (7)
Message 2 of 8
jeremytammik
Use the Autodesk.Revit.DB.Export method with DWGExportOptions or DWFExportOptions:
Afaik, you have to use the printing functionality for PDF export:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 8
Thank you so much for sharing the links.
Cheers,
Ali
Message 4 of 8
This code will export the  views  to  DWG files.
before using this command open the views(views you want to export(selected views)) .
Here GetOpenUIViews() will not get all the views instead it will get only  the opened views in the document
                  UIDOCUMENT uidoc;
                  DWGExportOptions Option = new DWGExportOptions();
                  Option.FileVersion = ACADVersion.R2010;
                  ICollection<ElementId> views = new Collection<ElementId>();
//GET ALL THE OPENED VIEWS IN THE DOCUMENT
                  IList<UIView> uiviewss = uidoc.GetOpenUIViews();
                                  foreach (UIView V in uiviewss)
                                              views.Add(V.ViewId);
//EXPORT AS DWG FILE
                      uidoc.Document.Export(@"C:\folder", @"filename.dwg", views, Option);
Message 5 of 8
Thanks @Anonymous I'll definitely check this code out. Do you know how to export sheets set in PDF format?
Message 6 of 8
Hi @jeremytammik I checked the link for auto-pdf-print. The code is well documented. However, when I used the PrintToPDF method in my addin the following error popup up while running the PrintManager.SubmitPrint(); method. Do you know the fix?
"Attempted to read or write protected memory. This is often an indication that another memory is corrupt"
Message 7 of 8
jeremytammik
Glad to hear it is well documented and you are able to run it. Nope, sorry, I do not know how to fix that. Good luck!
Jeremy Tammik
The Building Coder
Message 8 of 8
I think the error comes because of the  oPM.SelectNewPrintDriver("CutePDF writer"); do not run smoothly. however, by changing CutePDF writer to 'Microsoft Print to PDF"  the error got fixed. Thanks for those links, they really helped!
cheers,
Ali
