Connect Into
Connect Into
MarryTookMyCoffe
Connect Into
MarryTookMyCoffe
does any one know where in api I can find method for "Connect into". I what connect heater with pipe.
first i thought i can find in by a shortcut file but:
Dialog_BuildingSystems_RbsConnectIntoBar:Control_BuildingSystems_RbsConnectInto
don't tell me much
and it is not in a
Autodesk.Revit.DB.Plumbing.PlumbingUtils or in Autodesk.Revit.DB.Mechanical.MechanicalUtils
do not worry it only gonna take Autodesk 5 years to fix bug
jeremytammik
Does the functionality you require place a tap?
Here are two posts on that:
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Alternatively, there is also ConnectTo which just requires that you have identified both connectors.
Find the two connectors within their connector managers. ConnectTo comes straight from the connector itself.
If you call the pipe connector pipeConnector and the heater connector heaterConnector:
pipeConnector.ConnectTo(heaterConnector);
It won't draw any routing between the connectors, but it will establish a connection. I use this when I know that the connectors are reasonably close (usually doing a distance check between the two and making sure it's within 1/8" or so).
MarryTookMyCoffe
thx for replay, but it not what I was looking for.
I guss i have to make this my self.
Did you manage to find the API for Connect Into yet?
MarryTookMyCoffe
no, I did my own extension for it.
Cut pipe insert instance between and connect connector
