Export Revit shared parameter values to Excel using Lab4_2_ExportParametersToExcel
I am trying to export shared parameter to excel, just shared parameter values, I started from the great example Lab4_2_ExportParametersToExcel by Jeremy, but I couldn't make a filter to only shared parameter values only. Many Thanks.
#region Lab4_2_ExportParametersToExcel
/// <summary>
/// Export all parameters for each model
/// element to Excel, one sheet per category.
/// <include file='../doc/labs.xml' path='labs/lab[@name="4-2"]/*' />
/// </summary>
[Transaction( TransactionMode.ReadOnly )]
public class Lab4_2_ExportParametersToExcel
: IExternalCommand
public Result Execute(
ExternalCommandData commandData,
ref string message,
ElementSet elements )
UIApplication app = commandData.Application;
Document doc = app.ActiveUIDocument.Document;
// Extract and group the data from Revit in a
// dictionary, where the key is the category
// name and the value is a list of elements.
Stopwatch sw = Stopwatch.StartNew();
Dictionary<string, List<Element>> sortedElements
= new Dictionary<string, List<Element>>();
// Iterate over all elements, both symbols and
// model elements, and them in the dictionary.
ElementFilter f = new LogicalOrFilter(
new ElementIsElementTypeFilter( false ),
new ElementIsElementTypeFilter( true ) );
FilteredElementCollector collector
= new FilteredElementCollector( doc )
.WherePasses( f );
string name;
foreach( Element e in collector )
Category category = e.Category;
if( null != category )
name = category.Name;
// If this category was not yet encountered,
// add it and create a new container for its
// elements.
if( !sortedElements.ContainsKey( name ) )
sortedElements.Add( name,
new List<Element>() );
sortedElements[name].Add( e );
// Launch or access Excel via COM Interop:
X.Application excel = new X.Application();
if( null == excel )
LabUtils.ErrorMsg(
"Failed to get or start Excel." );
return Result.Failed;
excel.Visible = true;
X.Workbook workbook = excel.Workbooks.Add(
Missing.Value );
X.Worksheet worksheet;
// We cannot delete all work sheets,
// Excel requires at least one.
//while( 1 < workbook.Sheets.Count )
// worksheet = workbook.Sheets.get_Item(1) as X.Worksheet;
// worksheet.Delete();
// Loop through all collected categories and
// create a worksheet for each except the first.
// We sort the categories and work trough them
// from the end, since the worksheet added last
// shows up first in the Excel tab.
List<string> keys = new List<string>(
sortedElements.Keys );
keys.Sort();
keys.Reverse();
bool first = true;
int nElements = 0;
int nCategories = keys.Count;
foreach( string categoryName in keys )
List<Element> elementSet
= sortedElements[categoryName];
// Create and name the worksheet
if( first )
worksheet = workbook.Sheets.get_Item( 1 )
as X.Worksheet;
first = false;
else
worksheet = excel.Worksheets.Add(
Missing.Value, Missing.Value,
Missing.Value, Missing.Value )
as X.Worksheet;
name = ( 31 < categoryName.Length )
? categoryName.Substring( 0, 31 )
: categoryName;
name = name
.Replace( ':', '_' )
.Replace( '/', '_' );
worksheet.Name = name;
// Determine the names of all parameters
// defined for the elements in this set.
List<string> paramNames = new List<string>();
foreach( Element e in elementSet )
ParameterSet parameters = e.Parameters;
foreach( Parameter parameter in parameters )
name = parameter.Definition.Name;
if( !paramNames.Contains( name ) )
paramNames.Add( name );
paramNames.Sort();
// Add the header row in bold.
worksheet.Cells[1, 1] = "ID";
worksheet.Cells[1, 2] = "IsType";
int column = 3;
foreach( string paramName in paramNames )
worksheet.Cells[1, column] = paramName;
++column;
var range = worksheet.get_Range( "A1", "Z1" );
range.Font.Bold = true;
range.EntireColumn.AutoFit();
int row = 2;
// First column is the element id,
// second a flag indicating type (symbol)
// or not, both displayed as an integer.
worksheet.Cells[row, 1] = e.Id.IntegerValue;
worksheet.Cells[row, 2] = ( e is ElementType )
? 1
: 0;
column = 3;
string paramValue;
paramValue = "*NA*";
//Parameter p = e.get_Parameter( paramName ); // 2014
// Careful! This returns the first best param found.
Parameter p = e.LookupParameter( paramName ); // 2015
if( null != p )
//try
paramValue
= LabUtils.GetParameterValue( p );
//catch( Exception ex )
// Debug.Print( ex.Message );
worksheet.Cells[row, column++]
= paramValue;
} // column
++nElements;
++row;
} // row
} // category == worksheet
sw.Stop();
TaskDialog.Show( "Parameter Export",
string.Format(
"{0} categories and a total "
+ "of {1} elements exported "
+ "in {2:F2} seconds.",
nCategories, nElements,
sw.Elapsed.TotalSeconds ) );
return Result.Succeeded;
#endregion // Lab4_2_ExportParametersToExcel
