Export Revit shared parameter values to Excel using Lab4_2_ExportParametersToExcel
anmh2
anmh2
I am trying to export shared parameter to excel, just shared parameter values, I started from the great example Lab4_2_ExportParametersToExcel by Jeremy, but I couldn't make a filter to only shared parameter values only. Many Thanks.
#region Lab4_2_ExportParametersToExcel
  /// <summary>
  /// Export all parameters for each model
  /// element to Excel, one sheet per category.
  /// <include file='../doc/labs.xml' path='labs/lab[@name="4-2"]/*' />
  /// </summary>
  [Transaction( TransactionMode.ReadOnly )]
  public class Lab4_2_ExportParametersToExcel
    : IExternalCommand
    public Result Execute(
      ExternalCommandData commandData,
      ref string message,
      ElementSet elements )
      UIApplication app = commandData.Application;
      Document doc = app.ActiveUIDocument.Document;
      // Extract and group the data from Revit in a
      // dictionary, where the key is the category
      // name and the value is a list of elements.
      Stopwatch sw = Stopwatch.StartNew();
      Dictionary<string, List<Element>> sortedElements
        = new Dictionary<string, List<Element>>();
      // Iterate over all elements, both symbols and
      // model elements, and them in the dictionary.
      ElementFilter f = new LogicalOrFilter(
        new ElementIsElementTypeFilter( false ),
        new ElementIsElementTypeFilter( true ) );
      FilteredElementCollector collector
        = new FilteredElementCollector( doc )
          .WherePasses( f );
      string name;
      foreach( Element e in collector )
        Category category = e.Category;
        if( null != category )
          name = category.Name;
          // If this category was not yet encountered,
          // add it and create a new container for its
          // elements.
          if( !sortedElements.ContainsKey( name ) )
            sortedElements.Add( name,
              new List<Element>() );
          sortedElements[name].Add( e );
      // Launch or access Excel via COM Interop:
      X.Application excel = new X.Application();
      if( null == excel )
        LabUtils.ErrorMsg(
          "Failed to get or start Excel." );
        return Result.Failed;
      excel.Visible = true;
      X.Workbook workbook = excel.Workbooks.Add(
        Missing.Value );
      X.Worksheet worksheet;
      // We cannot delete all work sheets,
      // Excel requires at least one.
      //while( 1 < workbook.Sheets.Count )
      //  worksheet = workbook.Sheets.get_Item(1) as X.Worksheet;
      //  worksheet.Delete();
      // Loop through all collected categories and
      // create a worksheet for each except the first.
      // We sort the categories and work trough them
      // from the end, since the worksheet added last
      // shows up first in the Excel tab.
      List<string> keys = new List<string>(
        sortedElements.Keys );
      keys.Sort();
      keys.Reverse();
      bool first = true;
      int nElements = 0;
      int nCategories = keys.Count;
      foreach( string categoryName in keys )
        List<Element> elementSet
          = sortedElements[categoryName];
        // Create and name the worksheet
        if( first )
          worksheet = workbook.Sheets.get_Item( 1 )
            as X.Worksheet;
          first = false;
        else
          worksheet = excel.Worksheets.Add(
            Missing.Value, Missing.Value,
            Missing.Value, Missing.Value )
            as X.Worksheet;
        name = ( 31 < categoryName.Length )
          ? categoryName.Substring( 0, 31 )
          : categoryName;
        name = name
          .Replace( ':', '_' )
          .Replace( '/', '_' );
        worksheet.Name = name;
        // Determine the names of all parameters
        // defined for the elements in this set.
        List<string> paramNames = new List<string>();
        foreach( Element e in elementSet )
          ParameterSet parameters = e.Parameters;
          foreach( Parameter parameter in parameters )
            name = parameter.Definition.Name;
            if( !paramNames.Contains( name ) )
              paramNames.Add( name );
        paramNames.Sort();
        // Add the header row in bold.
        worksheet.Cells[1, 1] = "ID";
        worksheet.Cells[1, 2] = "IsType";
        int column = 3;
        foreach( string paramName in paramNames )
          worksheet.Cells[1, column] = paramName;
          ++column;
        var range = worksheet.get_Range( "A1", "Z1" );
        range.Font.Bold = true;
        range.EntireColumn.AutoFit();
        int row = 2;
          // First column is the element id,
          // second a flag indicating type (symbol)
          // or not, both displayed as an integer.
          worksheet.Cells[row, 1] = e.Id.IntegerValue;
          worksheet.Cells[row, 2] = ( e is ElementType )
            ? 1
            : 0;
          column = 3;
          string paramValue;
            paramValue = "*NA*";
            //Parameter p = e.get_Parameter( paramName ); // 2014
            // Careful! This returns the first best param found.
            Parameter p = e.LookupParameter( paramName ); // 2015
            if( null != p )
              //try
              paramValue
                = LabUtils.GetParameterValue( p );
              //catch( Exception ex )
              //  Debug.Print( ex.Message );
            worksheet.Cells[row, column++]
              = paramValue;
          } // column
          ++nElements;
          ++row;
        } // row
      } // category == worksheet
      sw.Stop();
      TaskDialog.Show( "Parameter Export",
        string.Format(
          "{0} categories and a total "
          + "of {1} elements exported "
          + "in {2:F2} seconds.",
          nCategories, nElements,
          sw.Elapsed.TotalSeconds ) );
      return Result.Succeeded;
  #endregion // Lab4_2_ExportParametersToExcel
FAIR59
parameters have a property IsShared.
       	if(!parameter.IsShared) continue;
       	if(!paramNames.Contains(parameter.Definition.Name)) paramNames.Add(parameter.Definition.Name);
Also shared parameters can have duplicate names ( even the same name as a BuiltInParameter  or project-parameter!!). I wouldn't use e.LookupParameter(paramName) but would loop through all the returned parameters from  e.GetParameters(paramName),
	foreach(Parameter p in e.GetParameters(paramName))
            if( p.IsShared)
            	//export paramName and value
                //and GUID
