Argument 1: cannot convert from 'System.Collections.Generic.IList<Autodesk.Revit.D.ElementId>' to 'Autodesk.Revit.DB.ElementId' (CS1503)
T52K-BIB
T52K-BIB
hi everyone,
how can I solve this error please help me.
namespace RevitAddin3
    [Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(
          ExternalCommandData commandData,
          ref string message,
          ElementSet elements)
            UIApplication uiapp = commandData.Application;
            UIDocument uidoc = uiapp.ActiveUIDocument;
            Application app = uiapp.Application;
            Document doc = uidoc.Document;
            //get input from form
            Form1 form = new Form1(commandData);
            form.ShowDialog();
            string name = form.rnumber;
            // get Room Element
            RoomFilter filter = new RoomFilter();
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            IList<Element> rooms = collector.WherePasses(filter).ToElements();
            // Get the active view of the current document.
            Autodesk.Revit.DB.View view = doc.ActiveView;
            if (view is Autodesk.Revit.DB.ViewPlan)
                foreach (Element e in rooms)
                    if (name == e.Name)
                        uidoc.Selection.SetElementIds(e.Id);
            else
                TaskDialog.Show("View", "Please make Sure Plan View");
                return Result.Failed;
            return Result.Succeeded;
sragan
I believe SetElementIds expects a collection of element id's.  You are trying to set it to a single ID.
Put your ID in a collection like ICollection<ElementId> and use that in the SetElementId's line.
mhannonQ65N2
You need to pass a list of element ids not a single ElementId.
IList<ElementId> ids = rooms.Where(e => e.Name == name).Select(e => e.Id).ToList();
uidoc.Selection.SetElementIds(ids);
T52K-BIB
@mhannonQ65N2
can i know What is e in your code?
