eTransmitt is showing error
ddgi.tech
ddgi.tech
While etransmitting files in Revit 2019 (version 2019.2.2), this error is showing and the files are failing to deliver. Tried to etransmit files from both BIM 360 and local drive, both showing the same error.
Please help.
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
