Explode Nested Familes
Dale.Bartlett
Message 1 of 9
Dale.Bartlett
This may or may not be considered an API task, but I thought this forum the best place to start. We have been provided with a model where the user has created a single generic family which contains several component families. For example, a bathroom layout with all the fixtures combined into a single generic family (not a group). This generic family needs to be "exploded" so that the nested component families become resident in the host project. It is not possible to copy/paste between family and project. Would anyone care to propose either a manual process or a pseudo code approach? Don't even ask why it was done this way... Dale
______________
Yes, I'm Satoshi.
Replies (8)
Message 2 of 9
jeremytammik
Dear Dale,
I suggest these steps:
  • Determine the bathroom family instance transform into the project Tb
  • Delete the bathroom instance
  • Open the family definition
  • For each fixture:
  • Determine the fixture family F and its instance transform into the family Tf
  • Insert F into the project using the transform Tf * Tb
  • Repeat for all fixtures
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 3 of 9
JimJia
Hi Dale,
There is no current API meet your requirement.
You need to do it manually as Jeremy mentioned above.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Email: Jim.Jia@autodesk.com
Message 4 of 9
With familyinstances based on Level it works. But with families based on faces of other familyinstance or on planes we can not do it.
Any example of how to insert into our project an element based on a face within a family, such as Familyinstance?
Message 5 of 9
jeremytammik
As always, I meant those steps to describe an API solution, actually.
As always, before programming it, you need to ensure it can be done manually as well.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 9
jeremytammik
Message 7 of 9
Hello Jeremy
I select a Familyinstance (oFi) and with this code I take out all the FamilyInstance sub-elements that it has inside.
But none of them gives me HOST or HOSTFACE, even though if I edit the family, I see that they take it.
How can I check out each Nested Familyinstance and check out HOST and HOSTFACE (if they have)
Do I have to edit the family to get them out, or is there another way?
Dim collector As New FilteredElementCollector(oDoc)
collector = collector.OfClass(GetType(Autodesk.Revit.DB.FamilyInstance)).OfCategory(BuiltInCategory.OST_GenericModel)
Dim query As System.Collections.Generic.IEnumerable(Of Autodesk.Revit.DB.FamilyInstance)
query = From element In collector
Where CType(element, FamilyInstance).SuperComponent IsNot Nothing AndAlso CType(element, FamilyInstance).SuperComponent.Id.Equals(oFi.Id)
Select CType(element, FamilyInstance)
Dim colFi As List(Of FamilyInstance) = query.ToList
Dim mensa As String = "Subfamilias = " & colFi.Count & vbCrLf
For Each oFih As FamilyInstance In colFi
Dim oHo As Element = oFih.Host
Dim oHoF As Reference = oFih.HostFace
mensa &= oFih.Name
If oHo IsNot Nothing Then mensa &= " (" & oHo.Name & ")"
If oHoF IsNot Nothing Then mensa &= " / (" & oDoc.GetElement(oHoF).Name & ")"
mensa &= vbCrLf
Next
MsgBox(mensa)
Message 8 of 9
I need to insert into the project each one of the Nested FamilyInstance that contains the family (Supercomponent)
So I need to know the Host and HostFace of each sub Familyinstance to create the SketchPlanes / Levels or similar and insert them into the project.
Message 9 of 9
LoganAC34
Just wanted to share my solution to this - see link below to my post on the Dynamo forum:
https://forum.dynamobim.com/t/how-to-explode-revit-families-similar-to-blocks-in-autocad/17015/4?u=l...
