api to make installer and install to revit
markjvlampad
markjvlampad
recently I finish my encoding using VS2013 and Revit 2016. now I want to deploy(create installer) how can I do that?
some mention to use WIX and Innosetup, also in some blog they mention to use oneclick to make the installer.
I agree with those because I manage to create one installer. but the problem after I install the add in, nothing is happen.
so what I did, I copy the add in file to revit correct location and make sure that I got correct path to reference my .dll.
what happen next, revit is now recognizing my add in. it displays correct name in Ribbon. but the panel didn't display anything(totally blank).
I'm not sure what exactly I missed out. can somebody give me a hint which areas in VS I need to check? or is there a blog I can read how to correctly deploy a revit add in.
cheers,
Mark
jeremytammik
Dear Mark,
The Revit API getting started material includes all the information you require:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
For a comprehensive and complete summary of the relevant information, you can also simply read the developer guide section on add-in installation:
http://help.autodesk.com/view/RVT/2018/ENU/?guid=GUID-4BE74935-A15C-4536-BD9C-7778766CE392
For a very complete and professional working sample single-click setup, you might want to check out the RevitPythonShell:
https://github.com/architecture-building-systems/revitpythonshell
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
MarryTookMyCoffe
if panel is empty it mean that you forget to add button to it.
here is a link to a best explanation how add buttons:
http://archi-lab.net/create-your-own-tab-and-buttons-in-revit/
do not worry it only gonna take Autodesk 5 years to fix bug
jeremytammik
Dear MarryTookMyCoffe,
Thank you for your succinct and precise answer, and also for pointing out the archi+lab blog.
I promoted both to a notice on The Building Coder to raise awareness for this:
http://thebuildingcoder.typepad.com/blog/2017/12/pipe-fitting-k-factor-archilab-and-installer.html#6
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
BKSpurgeon
I am developing a "hello world" Revit API dll.
I want to make this dll work on someone else's computer. My understanding is that a ClickOnce or MSI installer can be used to "install the dll" or "install the plugin".
Was seeking a pointer, because it seems a lot harder than it should be - my understanding of installation/deployment is that the dll + manifest file should be dumped in a certain specific path(s) on a user's computer based on what i read in the developer docs.
Any pointers would be much appreciated. Chrs!
@jeremytammik wrote:
Dear Mark,
Cheers,
Jeremy
jeremy_tammik
Nowadays, afaik, you can implement continuous integration CI on GitHub to build your installation DLL and installer MSI right there and then every time a new release is defined. Then the users can simply click on the GitHub release assets to install on their local machine, c.f., the RevitLookup releases:
