error to implement interface member 'Autodesk.Revit.DB.IExportContext
dwang30
dwang30
Hey
I got the following error when i build Revit .Net addin
Error    19    .... not implement interface member 'Autodesk.Revit.DB.IExportContext.OnDaylightPortal(Autodesk.Revit.DB.DaylightPortalNode)'. I am using Revit 2014.
Please help.
Thanks in advance
DW
jeremytammik
Read about how Visual Studio can automatically implement the interface for you.
There is no need for you to type anything at all.
This is a Visual Studio and .NET issue and has (almost) nothing to do with the Revit API.
Jeremy Tammik
Developer Technical Services
The Building Coder
dwang30
Hello Jeremy
Thank you very much. I am trying to building your code about "Revit va3c exporter". I am using Revit 2014 API. I got the error like 'Autodesk.Revit.DB.Element' does not contain a definition for 'GetOrderedParameters' and no extension method 'GetOrderedParameters'. It seems 2014 RevitAPI does't have this method in DB.Element. Could you please let me know what's the method in 2014 RevitAPI
Thank you for helping
DW
jeremytammik
get_Parameters, I think.
Jeremy Tammik
The Building Coder
dwang30
Hello Jeremy
That doesn't work.
Thank you for the help
DW
