Dynamic model update - how to AddTrigger for worksets (not elements)
boostyourbim
boostyourbim
I'd like to invoke an updater when worksets are created. But all overloads for UpdaterRegistry.AddTrigger require an ElementFilter, not a WorksetFilter.
Any ideas how this can be done?
Harry
FAIR59
As you say worksets aren't Elements, so an Updater won't work.  But when the user changes/adds/deletes worksets, Revit records a transaction named "Worksets".  So if you subscribe to the documentchanged event, you can test for the transaction name.
        void ControlledApplication_DocumentChanged(object sender, Autodesk.Revit.DB.Events.DocumentChangedEventArgs e)
            if (e.GetTransactionNames().Contains("Worksets"))
                // Check  document.GetWorksetTable() for new worksets
If you expect other Addin's to create worksets, then this will not work. (the transaction will have another name). In that case your only option is to use a timer to check periodically  for new worksets
boostyourbim
Thanks, but the document is in a read-only state during DocumentChanged so that doesn't help in this case.
FAIR59
Instead of doing something in the DocumentChanged method, you can launch an External Event and do your checks there.
matthew_taylor
Hi @boostyourbim,
If you're trying to enforce something (such as a naming standard), then you may able to use a custom FailureDefinition and a custom failure handler.
Can you say exactly what you're trying to do? It may sprout ideas.
Cheers,
-Matt
_______________________________________________________________________________
Marking a post as a 'solution' helps the community. Giving a post 'Kudos' is as good as saying thanks. Why not do both?
