Extract tesselated geometry from 2D component
pmeigneux
pmeigneux
I currently use the CustomExporter() function to extract tesselated geometry from the Revit Model.
I arrive to extract to obtain all 3D geometry from the 3D Revit component.
But I didn't find a way to extract 2D geometry with this approach.
For example, I put a RVT file in attachment with some pipes components which are not extracted.
Thanks for your support,
Philippe
jeremytammik
Dear Philippe,
Thank you for your query.
Yes, indeed, I am sorry to say that 2D geometry is not supported by the custom exporter.
I wish it were.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
pmeigneux
Hello Jeremy,
Thanks for your response.
Do you know if there is any workaround to obtain a tesselated component from 2D Geometry?
Philippe
jeremytammik
Dear Philippe,
Yes, sure.
Query the 2D element for its geometry in a view that provides what you need.
It will consist of curves, I presume.
Use Curve.Tessellate on them:
http://www.revitapidocs.com/2017/f95f3199-3251-c708-c5a3-a0e9ef95ecfa.htm
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
pmeigneux
Hello @jeremytammik,
I take a look to your previous answer and I need to precise our question.
Indeed, it seems Structural and MEP components have a different behaviour from the architectural component. So we didn't find a way to use Curve.Tesselate on MEP elements.
Do you know a way to extract these following informations from Structural or MEP components with CustomExporter():
  • extract tesselate geometry from Structural or MEP components, for example with (structural rebar or pipe see .rvt file in attachments)
  • color of 2D components;
  • transparency data on 2D component.
Thanks for your help,
Philippe
pmeigneux
Hello @jeremytammik
I finally succeed to extract a tesselated geometry from 2D MEP component with CustomExporter().
However, I didn't find a way to extract the color and transparency associated on the Materials.
Do you know a way to obtain the Materials.node on the MEP.Curve function?
Philippe
