Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Error Loading pyRevit in Revit 2019.2.6
2 REPLIES 2
scott.v
299 Views, 2 Replies
Hello All,
Based on the advice of Autodesk I upgraded Revit to the latest build of 2019, 2019.2.6.  I received a load error from pyRevit using the latest version.  Is this something I should be worried about?
As always I'm always nervous about doing any upgrades to Revit, but this is Autodesk's recommendation to avoid corrupt models on BIM 360.
Thank you.
Labels (4)
2 REPLIES 2
jeremy_tammik
in reply to: scott.v
I am by no means an expert on pyRevit. In fact, I don't know it at all. However, I would try to uninstall and reinstall it. If that does not help, I would suggest raising an issue for this on the pyRevit site or asking its author Ehsan:
https://github.com/eirannejad/pyRevit
scott.v
Thank you for your reply Jeremy.  I think that's a solid idea, one other team member installed pyRevit after doing the upgrade and he had no issues.
