Error Loading pyRevit in Revit 2019.2.6
scott.v
scott.v
Hello All,
Based on the advice of Autodesk I upgraded Revit to the latest build of 2019, 2019.2.6.  I received a load error from pyRevit using the latest version.  Is this something I should be worried about?
As always I'm always nervous about doing any upgrades to Revit, but this is Autodesk's recommendation to avoid corrupt models on BIM 360.
Thank you.
jeremy_tammik
I am by no means an expert on pyRevit. In fact, I don't know it at all. However, I would try to uninstall and reinstall it. If that does not help, I would suggest raising an issue for this on the pyRevit site or asking its author Ehsan:
https://github.com/eirannejad/pyRevit
scott.v
Thank you for your reply Jeremy.  I think that's a solid idea, one other team member installed pyRevit after doing the upgrade and he had no issues.
