Error installing add-in in revit 2020
Hi, in our company we used an add-in made by us that we install and works without problems in revit 2019.
We tryed to install it in revit 2020 and we had no problem, but when we run it, this message of error apears:
"Error Checking Latest Version".
Is this a commun error or an error that needs further analysis?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
you should update your .dll file from Revit 2019 to Revit 2020.
You can't expect the same .dll file from Revit 2019 to work in Revit 2020 because there will be some API changes from 2019 to 2020. So you need to make some changes.
Check the below Link
upgrading-your-api-applications-to-a-new-revit-version
I hope this helps.
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
I cannot open Revit 2020 on my Parallels 10.  I get an licence error message.  I have not used Revit 2020 for the past 2 months.  Please help me open my software.  Thank you
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
You mentioned "license error message".
Then this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage, or end-user support issues here
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not-for/td-p/5607765
The people there are much better equipped to answer your question than us.
I hope this clarifies.
Naveen Kumar T
