Error in Dynamo Add-In for Revit 2022
I’m developing a Dynamo add-in for Revit 2022 and encountering errors on specific lines in my code. Here’s what I have:
Error Messages:
- Line 20: [PushButton button = panel.AddPushButton("Run Dynamo", "RunDynamo", Assembly.GetExecutingAssembly().Location, "MyDynamoAddIn.RunDynamoCommand");]
- Line 39: [var dynamoController = DynamoController.Instance;]
I’ve checked that:
- The correct Revit and Dynamo API references are included.
- Dynamo is installed properly.
Can anyone help me figure out what might be going wrong? Thank you!
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Dynamo.Applications;
using Dynamo.Services;
using System;
using System.Reflection;
using Dynamo.Graph.Workspaces;
using System.Linq;
namespace MyDynamoAddIn
public class MyAddIn : IExternalApplication
public Result OnStartup(UIControlledApplication application)
RibbonPanel panel = application.CreateRibbonPanel("My Dynamo Panel");
return Result.Succeeded;
public Result OnShutdown(UIControlledApplication application)
public class RunDynamoCommand : IExternalCommand
Result IExternalCommand.Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
string dynamoFilePath = @"C:\Path\To\Your\DynamoScript.dyn"; // Update with your path
// Start Dynamo and open the script
dynamoController.Open(dynamoFilePath);
