Error in Dynamo Add-In for Revit 2022
elango_saramani
elango_saramani
I’m developing a Dynamo add-in for Revit 2022 and encountering errors on specific lines in my code. Here’s what I have:
Error Messages:
  • Line 20: [PushButton button = panel.AddPushButton("Run Dynamo", "RunDynamo", Assembly.GetExecutingAssembly().Location, "MyDynamoAddIn.RunDynamoCommand");]
  • Line 39: [var dynamoController = DynamoController.Instance;]
  • I’ve checked that:
    • The correct Revit and Dynamo API references are included.
    • Dynamo is installed properly.
    Can anyone help me figure out what might be going wrong? Thank you!
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Dynamo.Applications;
using Dynamo.Services;
using System;
using System.Reflection;
using Dynamo.Graph.Workspaces;
using System.Linq;
namespace MyDynamoAddIn
public class MyAddIn : IExternalApplication
public Result OnStartup(UIControlledApplication application)
RibbonPanel panel = application.CreateRibbonPanel("My Dynamo Panel");
return Result.Succeeded;
public Result OnShutdown(UIControlledApplication application)
public class RunDynamoCommand : IExternalCommand
Result IExternalCommand.Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
string dynamoFilePath = @"C:\Path\To\Your\DynamoScript.dyn"; // Update with your path
// Start Dynamo and open the script
dynamoController.Open(dynamoFilePath);
moturi.magati.george
Hi @elango_saramani
Kindly try asking the question on the Dynamo forum. There are more knowledgeable dynamo developers on the platform than here.
https://forum.dynamobim.com/
  Moturi George,     Developer Advocacy and Support,  ADN Open
j0hnp
I have a thorough sample for using Dynamo graphs within a C# Revit plugin here:
https://github.com/johnpierson/Relay/blob/master/src/Methods/DynamoMethods.cs
Compare your methods to that, and I bet you can get it sorted.
john.pierson
expert elite / design technologist / dynamo package creator
designtechunraveled.com
elango_saramani
Hi
Thank you for your Reply. I have attached the image below. Could you kindly advise me on this?
Mohamed_Arshad
Hi @elango_saramani
Have you check the below link?
Re: Dynamo script in Revit API - Page 2 - Autodesk Community
Mohamed Arshad K
Software Developer (CAD & BIM)
