Change Arrowhead Tick Size to Instance Parameter
emma_hundsdorferS6VHG
Observer Observer
Observer
Observer
Background: We currently have our wall/roof tags with leader lines set to Heavy Line. We are trying to get it so that the Heavy Line "tick" goes through the entire width of the wall/roof, but there are so many instances of different widths that creating a new "Heavy Line" arrowhead type and then a new Wall Tag type for each instance is not a realistic solution.
Question: How difficult would it be to change a System Family parameter (Arrowhead "Tick Size") to instance? Preferably where you can drag the length similar to section markers, but typing the length is fine too.
I have looked into API solutions and Dynamo solutions, I am advanced in Revit but I am new to the coding side so it is feeling in over my head for the moment. Any advice or solutions?
ctm_mka
I'm going to say that's not possible the way you describe it, the best i think you could do is exactly what you don't want to (create new types & tags). Instead i would suggest creating a annotation family with the instance parameters you want.
