Embed Video in ToolTip
RickyBell
Message 1 of 8
RickyBell
I found Jeremy's article from 2012 ( http://thebuildingcoder.typepad.com/blog/2012/09/video-animated-ribbon-item-tooltip.html ) that shows how to embed a swf file in Revit 2012's Ribbon.  Is there an updated proceedure for 2014/2015?  Looking through the help file and SDK and I'm finding nothing relating to tooltip videos.
Thanks!
Accepted solutions (3)
Replies (7)
Message 2 of 8
Aaron.Lu
Dear Ricky, what type of video do you want to embed, have you tried Jeremy's method? if yes, would you let us know what is the problem?
thanks.
Aaron Lu
Developer Technical Services
Autodesk Developer Network
Message 3 of 8
RickyBell
Thanks for the reply Aaron,
I haven't come across any other method than the one just I linked to.  I'll embed any type of video it will let me.  The example I found on Friday was for a Flash Video file.  With the 2015 API I was unable to find anything on the ExpandedContent or the RevitToolTip Class.
Thanks for your help.
Message 4 of 8
Aaron.Lu
What about using same code but only changing the .swf to whatever your video format? you can let us know the result or the error message.
thanks
Aaron Lu
Message 5 of 8
RickyBell
Ok, so I got his example compiling.  I was having issues with namespaces and such.  I got it figured out thanks to his example project and good ol' copy and paste.  In Revit (2014), when I hover over any of his three example buttons, I get "Video is loading..." and an error message.  "AdFlashVideoPlayer Library not registered."
Almost there.  Any ideas?  Thanks.
Message 6 of 8
RickyBell
Alright, it's working.  Sorry to waste your time.  The example is good and it's not too hard to implement.
The error message was because I didn't have the Flash Player for ActiveX/Internet Explorer installed on my development machine.  Thanks for your help!
Message 7 of 8
RickyBell
To add to the list of compatible video files, I found that embedding your video file in the swf file works.  FLV (Flash Video Format, vp6 codec) will come in the easiest.  M4V Files require flash to put in a small player, but work great.  It looks like anything that uses the H.264 codec will also work.  Hope this helps someone trying to do ToolTip Videos.
Message 8 of 8
Aaron.Lu
Cool 😉
Aaron Lu
