ElementTransformUtils.MirrorElements error when upgrading Revit API 2024
ptranU2KHX
Message 1 of 35
ptranU2KHX
Hi everyone,
I have a very simple project and I'd like to mirror them. Link to project if you'd like to download mirror
My code works fine with Revit API 2023 but not Revit API 2024.
Looking at the Revit API 2024 change, I see a section related to mirror thing.
I try to use the check mirror posibility before executing but it always returns me true value.
Please help. Thank you.
Replies (34)
Message 21 of 35
jeremy_tammik
They reply: Unfortunately, for more complicated projects, I would recommend that the user wait until we expose a proper mirror project API. We cannot guarantee that there is enough API to do all the work we do internally that makes sure this complex mirroring operation succeeds. Sorry for the bad news.
Message 22 of 35
ptranU2KHX
Hi @jeremy_tammik
Thank you for your information.
Besides, if you can, please let us know when a new mirror project API is released. This piece of information will help us in planning our development.
Message 23 of 35
jeremy_tammik
Sure. Beside that, I would also suggest that you keep an eye on the roadmap for future development directions and the What's New sections in the Revit SDK API documentation for enhancements and additions in each new release.
Message 24 of 35
jeremy_tammik
Dear Phat Tran,
Thank you for your patience.
The development team has made further progress with the analysis of this issue.
The ticket REVIT-207038 [MirrorElements fails although CanMirrorElements returns true] is closed as a duplicate.
We have filed an improvement task for implementing an API that would cover more complex workflows: REVIT-209138 [Implement Mirror elements in the API]. More work needs to be done that we need to plan on our side. Please make a note of this number for future reference.
Best regards,
Jeremy
Message 25 of 35
dbrainard
Hello Jeremy,
I wanted to inquire about a status update on this issue. We did some testing after the Revit 2024.1 release but it did not seem to change the results of flipping the project using the ElementTransformUtils.MirrorElements method explained here. Also, I think we observed far more errors related to spot slops, dimensions and generic annotations when manually mirroring projects in 2024.0 then we're seeing now in Revit 2024.1 which is interesting. Nonetheless, in order for us to resolve our product issue we either need the TransformUtils to behave as they did in prior releases or we need some new dedicated calls to handle the Mirror Project operations.
I appreciate your time and Thank You! -Dave
Case Reference: REVIT-207038 [MirrorElements fails although CanMirrorElements returns true]
Message 26 of 35
jeremy_tammik
Dear Dave,
Thank you for your update and observations.
Please note that the currently active case reference for covering the more complex mirroring workflows is REVIT-209138 [Implement Mirror elements in the API].
I added your notes to that and asked the development team for an update on its current status.
Best regards,
Jeremy
Message 27 of 35
jeremy_tammik
Phat Tran asked via the DAS portal:
> Where can I find REVIT-209138 [Implement Mirror elements in the API] as mentioned in the Revit forum's post?
Thank you for your query via DAS, Autodesk Developer Advocacy and Support. Let's please continue the discussion in your original thread in the Revit API discussion forum.
The development ticket REVIT-209138 [Implement Mirror elements in the API] is for internal tracking purposes, and external access is not available, so you cannot find it yourself. Asking about the status here in this thread is the best way to communicate about it.
I just added Dave's notes to it and asked the development team for a status update. Thank you for your patience.
Best regards,
Jeremy
Message 28 of 35
ptranU2KHX
Hi @jeremy_tammik
I hope you are doing great. I want to ask for a status update about this ticket.
Please help.
Thank you.
Message 29 of 35
jeremy_tammik
Dear Phat Tran
Thank you for the prompt. It seems that the ticket has not been processed at all yet. It is still unassigned.
It is marked as duplicated by another issue that has been successfully processed and closed, REVIT-207038 MirrorElements fails although CanMirrorElements returns true. That is obviously a much more trivial matter than your concern. Maybe this caused them to assume that no further action is required.
I added your prompt to it and requested a new review.
Thank you for your patience and sorry for the delay.
Best regards,
Jeremy
Message 30 of 35
ptranU2KHX
Hi @jeremy_tammik
Thank you for your information. Actually, we are talking about this ticket REVIT-209138 [Implement Mirror elements in the API].
You already told us REVIT-207038 [MirrorElements fails although CanMirrorElements returns true] was closed a while ago.
Phat.
Message 31 of 35
jeremy_tammik
Dear Phat Tran
Yes, exactly. The ticket REVIT-209138 [Implement Mirror elements in the API] has not been processed at all yet. It is still unassigned.
Best regards,
Jeremy
Message 32 of 35
chmillerKR3SZ
Observer
Observer
Jeremy, Thank you for all your assistance on this issue.  Is there any update on this or whether this has been addressed in the 2025 release of Revit?
Message 33 of 35
bmeltonSST
Hi @jeremy_tammik ,
I am reaching out to see if there have been any updates to the status of this item (REVIT-209138 [Implement Mirror elements in the API] )? Especially anything that might be within the new Revit 2025. We haven't noticed anything in the documentation, however if there is something that we've missed, please let us know. Thank you in advance for any updates that you're able to provide!
Bryce
Message 34 of 35
jeremy_tammik
Dear Bryce,
I checked the status of the ticket REVIT-209138 [Implement Mirror elements in the API]. Unfortunately, it has not yet received significant attention. I also received no answer from the development team on my previous request for feedback. I have now re-prompted them and will let you know as soon as I hear back.
Sorry for the delay and thank you for your patience.
Best regards,
Jeremy
Message 35 of 35
jeremy_tammik
... progress: promoted to "sprint candidate", at least...
