ElementIntersectsElementFilter is not working for Lineked documents elements.
s04049
s04049
Hi
I am trying to find the intersect element between the selected element with the link file element.
When running the [Current_document] with [Current_document_element]
FilteredElementCollector(Current_document)
everything is fine.
However running the [Link_document] with [Current_document_element]
FilteredElementCollector(Link_document)
nothing filters to result from the list
List<Element> resultele = new FilteredElementCollector(Link_document).WhereElementIsNotElementType().WherePasses(new ElementIntersectsElementFilter(Current_doc_element)).ToList();
I found this post on forums that says this is a software glitch.
I try to run on 2023 and 2021 and still get the same result.
https://forums.autodesk.com/t5/revit-api-forum/elementintersectselementfilter-is-not-working-for-lin...
thanks for any help
jeremy_tammik
I am unsure whether you can run an ElementIntersectsElementFilter to directly analyse the current document with a linked document.  Afaik, a filtered element collector can only work in one document at a time.  If you are interested in a limited set of elements in either one of the two documents, you can retrieve their solid geometry, transform it to the other document coordinate space and use a ElementIntersectsSolidFilter on that instead.
