External Tools buttom
Ali.sadeghi.h1994
Ali.sadeghi.h1994
Hello. I started to make a Plugin in Revit2023. External Tools Button is not available in Add-in Tab. Could somebody help me?
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Ali.sadeghi.h1994 ,
Did you create an add-in file and load the add-in into Revit?
Please take a look at Writing an AddIn Manifest topic from the below link
https://knowledge.autodesk.com/search-result/caas/simplecontent/content/lesson-1-the-basic-plug.html
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Ali.sadeghi.h1994
I found solution. @longt61 advice helped me.
I did not put the add-in file in the correct folder. The assembly (dll) file can be any where you want, but the addin file must be in the 2 special folders for Revit to detect it. By default, these folders are:
2.1. C:\ProgramData\Autodesk\Revit\Addins\your_revit_version
2.2. C:\Users\user_name\AppData\Roaming\Autodesk\Revit\Addins\your_revit_version
