Edit family in project, delete materials, reload back to the project
h_echevarria
h_echevarria
I am trying to create a command that opens all the detail items in a project, cleans the family by turning off annotation categories (for the thumbnail), delete materials, etc.
So far I have managed to use the EditFamily method to open the families, hide the categories, and then reload back to the project with LoadFamily(targetDoc,IFamilyLoadOptions). However, I cannot delete the materials. I have a method that successfully work if I test it directly inside the family.
for (int i = 0; i < detailItems.Count(); i++)
    Family fam = detailItems[i];
    if (!fam.IsEditable) continue;
    Document famdoc = doc.EditFamily(fam);
    HideCategories(famdoc);
    DeleteMaterials(famdoc);
    Family outputfamily = famdoc.LoadFamily(doc, new FamilyLoadOptions());
    //bool isclosed = famdoc.Close(false);
So in the code above the Hide Categories method works: after reloading back the family, if I edit it I can see that the categories are hidden. However, the DeleteMaterials method is not working. It is curious because if I create a material collector after running the method it returns 0 materials. But when I open the family again, all the materials are there.
Here is the code  for deleting materials:
private void DeleteMaterials(Document doc)
    FilteredElementCollector collector = new FilteredElementCollector(doc);
    List<ElementId> materialIds = collector.OfClass(typeof(Material)).Select(x => x.Id).ToList();
    using (Transaction t = new Transaction(doc, "delete materials"))
        t.Start();
        doc.Delete(materialIds);
        t.Commit();
And here the IFamilyLoadOptions:
public class FamilyLoadOptions : IFamilyLoadOptions
    public bool OnFamilyFound(bool familyInUse, out bool overwriteParameterValues)
        overwriteParameterValues = true;
        return true;
    public bool OnSharedFamilyFound(Family sharedFamily, bool familyInUse, out FamilySource source, out bool overwriteParameterValues)
        source = FamilySource.Family;
        return true;
I suspect it has to do something with the transactions. But I don't receive any warnings. I also try to regenerate after deleting the materials, but it didn't work.
Any ideas? Many thanks
h_echevarria
Well...
I was about to give up and then I realised that I was using Regenerate() inside the family docs and not in the target Document. Using Regenerate() in the target document works!
h_echevarria
False alarm, it seems like it's working because it keeps the family open in the background. So when I click edit it opens the already opened family which has no materials. But if I close the families programmatically it will still load the family with all the materials. Strangely, some of the actions work, and others don't. For example, I can hide categories and change units, but I cannot delete materias and I  cannot change line patterns
h_echevarria
Update: It turns out that you get the same behaviour non-programmatically ಥ_ಥ
