Cannot find RevitUIAPI.dll even after adding to vs studio references in project
ryan_chesnut
ryan_chesnut
Having an issue accessing the RevitUIAPI.dll in code. RevitAPI.dll
See code screenshot. Using Revit 2025 and .NET8.0
jeremy_tammik
Have you installed Revit on your local system? I suggest that you add the references to the Revit API assembly DLL manually and browse to their location in the same directory as Revit.exe itself in the Visual Studio  UI. Also, make sure to set their Copy Local flag to false.
ryan_chesnut
Got it sorted, took a couple add and remove references
Thanks for the quick responses here. Getting acclimated to the development process.
