Edge reference of a family instance
Message 1 of 12
I'm trying to create a tool that will host an adaptive component on an edge in the project environment. The tool should prompt for an adaptive family to host and then for the edge to host it on.
I created the following helper method:
        Function HostOnEdge(document As Document, familyTohost As FamilySymbol, edgeReference As Reference, normalizedParameter As Double) As FamilyInstance
            'create a family instance and get it's adaptive points
            Dim familyInstance As FamilyInstance = AdaptiveComponentInstanceUtils.CreateAdaptiveComponentInstance(document, familyTohost)
            Dim placementPoints As IList(Of ElementId) = AdaptiveComponentInstanceUtils.GetInstancePlacementPointElementRefIds(familyInstance)
            'create reference point
            Dim location As New PointLocationOnCurve(PointOnCurveMeasurementType.NormalizedCurveParameter, normalizedParameter, PointOnCurveMeasureFrom.Beginning)
            Dim pointOnEdge As PointOnEdge = document.Application.Create.NewPointOnEdge(edgeReference, location)
            'attach first adaptive point to ref point
            Dim firstPoint As ReferencePoint = TryCast(document.GetElement(placementPoints(0)), ReferencePoint)
            firstPoint.SetPointElementReference(pointOnEdge)
            Return familyInstance
        End Function
I then call it from an external command as follows:
'select family to host Dim selectedElementId As ElementId = UiDocument.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element, "Select Element To Host:").ElementId 'select edge Dim selectedEdge As Reference = UiDocument.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Edge) 'get the selected elements family symbol Dim familyInstance As FamilyInstance = TryCast(Document.GetElement(selectedElementId), FamilyInstance) Dim familySymbol As FamilySymbol = familyInstance.Symbol 'create hosted element HostOnEdge(Document, familySymbol, selectedEdge, 0.5)
If I select a system family like a floor edge or a wall edge as the host it works as expected. (see attached GIF) If i select an edge of a loaded family such as a beam an internal exception is thrown (snippet attached). What is the correct way to create a pointOnEdge on an edge of a family instance?
Replies (11)
Message 2 of 12
FAIR59
the cause of your problem, Revit has 2 ways of calculating solids.
see my answer to https://forums.autodesk.com/t5/revit-api-forum/incorrect-face-normal/td-p/7108787
In this case, I think it's an error in the Revit-API.  The perfect valid EdgeReference ( of the "SolidInstance") apparently can't be used in the  firstPoint.SetPointElementReference() method. I say perfect valid, because you can use the EdgeReference for the creation of a Dimension without a problem.
If you have a familyInstance that is cut, joined (or Coped) your code will work.
Message 3 of 12
Thanks for the tip. As suggested if the "host" family is joined/cut/copped by another element it works as expected. If not the exception is thrown.
Message 4 of 12
jeremytammik
Dear Brett,
Thank you for your query, and many thanks to Fair59 for his many invaluable answers!
This and related issues have come up a number of times in the past, besides the thread that Fair59 points to on the incorrect face normal:
The question is whether the family instance geometry is returned in local or world coordinates, in LCS or WCS.
Another example:
Some related blog posts:
Have you tried using the `GetInstanceGeometry` method taking a `Transform` argument, and passing in an identity transform to it?
The docs recommend avoiding it in general, but you might call that as an alternative if you hit your exception.
I hope this helps.
Please do let us know how you solve this, since a blog post summarising the situation and providing the ultimate answer is long overdue.
Thank you!
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 5 of 12
jeremytammik
By the way, The Building Code never discussed the AdaptiveComponentInstanceUtils class... can you say something about what it is, how you use it, in what way you find it useful, what functionality it provides not found elsewhere, SDK samples demonstrating its use, etc.?
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 12
FAIR59
@jeremytammik nice collection of documentation / information. Sadly this problem has to do with hosting a Adaptive Point on a "real" Edge, so work arounds creating clones won't solve the issue.
I still think it's a bug in the Reference.SetPointElementReference(pointOnEdge) method. Looks to me there is a transformation to world coordinates missing somewhere.
  • For a Element with "in situ" geometry (element cut, joined or coped), Brett's code works.
  • Reworking the code to get a reference to a Voodoo-magic Edge (no transformation required) , the code works.
Only in the circumstances of the query does the code fail. (transformation to world coordinates required)
Having said that, we can trick Revit into placing the adaptive family in the right place.
These are the steps:
  1. Find start and End point of selected Edge.
  2. Place a dummy Element
  3. Join the dummy with the FamilyInstance containing the selected Edge, creating "in situ " geometry.
  4. Find the new Edge Reference of the "in Situ" geometry  with correct start and End point.
  5. Place adaptive Family on that Edge.
  6. Delete dummy element.
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public class Fa_HostAdaptiveFamilyOnEdge_Trick : IExternalCommand
        public Result Execute(ExternalCommandData revit, ref string message, ElementSet elements)
            Document doc = revit.Application.ActiveUIDocument.Document;
            var selectedElementId = ElementId.InvalidElementId;
            //select family to host
            try
              selectedElementId   = revit.Application.ActiveUIDocument.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element, "Select Element To Host:").ElementId;
            catch
                return Result.Failed;
            //get the selected family symbol to host on edge
            var familyInstance = doc.GetElement(selectedElementId) as FamilyInstance;
            if (familyInstance == null) return Result.Failed;
            var familySymbol = familyInstance.Symbol;
            //select edge
            Reference selectedEdge = null;
            try
                selectedEdge = revit.Application.ActiveUIDocument.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Edge);
            catch
            if (selectedEdge == null) return Result.Succeeded;
            bool SolidInstance =  selectedEdge.ConvertToStableRepresentation(doc).Contains("INSTANCE");
            Element el = null;
            FamilySymbol dummy = null;
            XYZ startPt = XYZ.Zero;
            XYZ endPt = XYZ.Zero;
            if (SolidInstance)
                el  = doc.GetElement(selectedEdge.ElementId);
                dummy  = (el as FamilyInstance).Symbol;
                Transform elTrans = (el as FamilyInstance).GetTransform();
                GeometryObject geoobj = el.GetGeometryObjectFromReference(selectedEdge);
                Edge selEdge = geoobj as Edge;
                startPt = elTrans.OfPoint( selEdge.AsCurve().GetEndPoint(0));
                endPt = elTrans.OfPoint( selEdge.AsCurve().GetEndPoint(1));
            using (Transaction t = new Transaction(doc, "create adaptive family"))
                t.Start();
                    FamilyInstance dummyInstance = null;
                    if (SolidInstance)
                        using (SubTransaction st = new SubTransaction(doc))
                            st.Start();
                            dummyInstance = doc.Create.NewFamilyInstance(new XYZ(double.MinValue, double.MinValue, 0), dummy, XYZ.BasisX, null, StructuralType.NonStructural);
                            st.Commit();
                            st.Start();
                            JoinGeometryUtils.JoinGeometry(doc, dummyInstance, el);
                            st.Commit();
                        Options options = new Options();
                        options.ComputeReferences = true;
                        options.View = doc.ActiveView;
                        GeometryElement geoElem = el.get_Geometry(options);
                        bool quitloop = false;
                        // find the "InSitu:" Edge
                        foreach (GeometryObject geoobj in geoElem)
                            Solid solid = geoobj as Solid;
                            if (solid == null) continue;
                            foreach (Edge e in solid.Edges)
                                XYZ pt1 = e.AsCurve().GetEndPoint(0);
                                XYZ pt2 = e.AsCurve().GetEndPoint(1);
                                if (pt1.IsAlmostEqualTo(startPt) || pt1.IsAlmostEqualTo(endPt))
                                    if (pt2.IsAlmostEqualTo(startPt) || pt2.IsAlmostEqualTo(endPt))
                                        selectedEdge = e.Reference;
                                        quitloop = true;
                                        break;
                            if (quitloop) break;
                    FamilyInstance famInst = null;
                    ReferencePoint firstPoint = null;
                        try
                            st.Start();
                            //create a family instance and get it's adaptive points
                            famInst = AdaptiveComponentInstanceUtils.CreateAdaptiveComponentInstance(doc, familySymbol);
                            List<ElementId> placementPoints = AdaptiveComponentInstanceUtils.GetInstancePlacementPointElementRefIds(famInst).ToList();
                            //create reference point
                            PointLocationOnCurve location = new PointLocationOnCurve(PointOnCurveMeasurementType.NormalizedCurveParameter, 0.5, PointOnCurveMeasureFrom.Beginning);
                            PointOnEdge pointOnEdge = doc.Application.Create.NewPointOnEdge(selectedEdge, location);
                            //attach first adaptive point to ref point
                            firstPoint = doc.GetElement(placementPoints.FirstOrDefault()) as ReferencePoint;
                            firstPoint.SetPointElementReference(pointOnEdge);
                            st.Commit();
                        catch {
                                                TaskDialog.Show("catch","Failed to place on selectededge  "+selectedEdge.ConvertToStableRepresentation(doc));
                    if (SolidInstance)
                            st.Start();
                            doc.Delete(dummyInstance.Id);
                            st.Commit();
                t.Commit();
Message 7 of 12
dusting of this old thread...
Seems like an easy enough workaround. Before i go and code it up, after the dummy element is deleted does the hosted element remain? is it still hosted?
I tried this approach manually, (see attached) when the dummy element is deleted the hosted element gets deleted also.
Message 8 of 12
FAIR59
You placed the adaptive family on a edge that was formed by cutting the 2 elements. When you remove the cutting element, you also remove the edge ( the host for the adaptive family)
Because I place the dummy element way off, there is no interaction with the selected edge, and the edge doesn't change as the dummy element is
removed.
Message 9 of 12
ok i see that now will give it a go.
The way Revit works never fails to surprise me.
Thank you for you help.
Message 10 of 12
minet.axel
Hello everyone,
I come to the news about this problem. I did some tests and I noticed that it only works with family categories that can be joined/cut/copped (example category: Walls, Framing, Generic Models). But I want to perform this operation on the specialized equipment category but it does not work. Would you have a solution for categories that can not be joined/cut/copped?
Message 11 of 12
minet.axel
I found!
I replaced this part of code with
    st.Start();
    st.Commit();
by
    st.Start();
    SolidSolidCutUtils.AddCutBetweenSolids(doc, dummyInstance, el);
    st.Commit();
Works with "Speciality Equipment"
Message 12 of 12
jeremytammik
Congratulations! Could you provide am minimal reproducible case that demonstrates the usage of your solution?
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
This seems to be a pretty tricky issue with some high level research and discussion invested, so it would be really nice to summarise in a conclusive blog post...
Thank you!
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
