REST POST Formating
REST POST Formating
REST POST Formating
Can anyone provide a code example of the following POST description from the API Reference pdf?
POST
/{sourceObjectPath}?destinationObjectPath={destinationObjectPath}&pasteAction={pasteAction}&repl
aceExisting={replaceExisting}
with actual paths, quotes and line ending as it would appear in code? Thank you.
jeremytammik
Dear Bryan,
Thank you for your query.
All I have off-hand is this old blog post with the happy conclusion 'works like a charm':
http://thebuildingcoder.typepad.com/blog/2014/01/rest-post-request-to-revit-server-2014.html
It is not much more explicit than your query, though.
As far as I know, you do not have to include any quotes or line endings in the request.
Replace the path separator character by the vertical bar sign '|'.
Avoid all spaces in file names.
That's about it, I think.
Any further quotes and stuff depend on your programming system.
The 'Revit Server REST API Reference.pdf' documentation includes an example:
Example:
The following example moves 00Folder\01CentralModel.rvt to 10Folder.
Request:
  POST /10Folder|01CentralModel.rvt?destinationObjectPath=00Folder|01CentralModel.rvt&pasteAction=Move&replaceExisting=false
  User-Name: Tester 31
  User-Machine-Name: TestMachine
  Operation-GUID: 45FB8158-8BE3-43E5-9DFA-318BDBCB4C93
Response:
  HTTP/1.1 201 Created
  Content-Length: 0
  Location: http://host/RevitServerAdminRESTService2017/10Folder|01CentralModel.rvt
Another solution would be to make use of the high-level Revit Server API library:
http://thebuildingcoder.typepad.com/blog/2017/02/revitserverapilib-truss-members-and-layers.html#2
Then you presumably don't have to deal with those nitty-gritty details yourself at all.
Alternatively, look into that library's source code to see how the POST request is formatted.
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
