dwg import option - SetLayerSelection doesn't work
Eri.Myalitsin
Eri.Myalitsin
Hello everyone,
I am trying to set the dwg's layers to import into Revit by using 'SetLayerSelection'.
But it doesn't work with the following code:
// DWG Import Options
DWGImportOptions dwgImportOption = new DWGImportOptions();
ICollection<string> layerSelection = new List<string>() { "layername" };
dwgImportOption.ColorMode = Autodesk.Revit.DB.ImportColorMode.BlackAndWhite;
dwgImportOption.CustomScale = 0.0;
dwgImportOption.Unit = Autodesk.Revit.DB.ImportUnit.Millimeter;
dwgImportOption.OrientToView = true;
dwgImportOption.Placement = Autodesk.Revit.DB.ImportPlacement.Origin;
dwgImportOption.ThisViewOnly = false;
dwgImportOption.SetLayerSelection( layerSelection );
I would highly appreciate if you could support me.
Thank you.
Eri.Myalitsin
There was the same problem as mentioned on this article:
http://thebuildingcoder.typepad.com/blog/2015/12/au-ioc-banks-and-not-to-delete-while-iterating.html
The following code made the error:
// View in current document
FilteredElementCollector coll = new FilteredElementCollector(doc);
coll.OfClass(typeof(View));
foreach(Element e in coll)
    if (e.Name == "Z0")
        View view = e as View;
        imported = doc.Import(m_fileName, dwgImportOption, view, out elementId);
Solution was like this:
var viewIds = coll.OfClass(typeof(View)).ToElementIds();
foreach(var id in viewIds)
    var view = doc.GetElement(id) as View;
    if (view.Name == "Z0")
