- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
I am trying to set the dwg's layers to import into Revit by using 'SetLayerSelection'.
But it doesn't work with the following code:
// DWG Import Options
DWGImportOptions dwgImportOption = new DWGImportOptions();
ICollection<string> layerSelection = new List<string>() { "layername" };
dwgImportOption.ColorMode = Autodesk.Revit.DB.ImportColorMode.BlackAndWhite;
dwgImportOption.CustomScale = 0.0;
dwgImportOption.Unit = Autodesk.Revit.DB.ImportUnit.Millimeter;
dwgImportOption.OrientToView = true;
dwgImportOption.Placement = Autodesk.Revit.DB.ImportPlacement.Origin;
dwgImportOption.ThisViewOnly = false;
dwgImportOption.SetLayerSelection( layerSelection );
I would highly appreciate if you could support me.
Thank you.
