Duplicating view
Duplicating view
neelDZKPU
Duplicating view
neelDZKPU
I have created some script to duplicate a view by selecting it. after selecting the view using pickobject method, Its showing error, my view is null. I think problem is in converting reference to view.
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using Autodesk.Revit.Attributes;
using System.Xml.Linq;
namespace MyRevitCommands
[TransactionAttribute(TransactionMode.Manual)]
internal class DuplicateView : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
//Get UIdoc
UIDocument uidoc = commandData.Application.ActiveUIDocument;
// Get doc
Document doc = uidoc.Document;
try
// pick view
Reference pickobj = uidoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element);
if (pickobj != null)
View view = doc.GetElement(pickobj) as View;
using (Transaction transaction = new Transaction(doc, "Duplicate View"))
transaction.Start();
ElementId newViewId = view.Duplicate(ViewDuplicateOption.Duplicate);
transaction.Commit();
TaskDialog.Show("View ", view.Name + "is duplicated");
return Result.Succeeded;
catch (Exception e)
message = e.Message;
return Result.Failed;
Mohamed_Arshad
HI @neelDZKPU
    Your problem is not in Conversion, problem in PickObject Method (ObjectType) Method. You can't be able to pick views because it is outside the UIDocument. So instead of PickObject Method (ObjectType) you can use GetElementIds Method Kindly refer the below code.
1. First you need to select the View and then click on the plugin.
Reference Code :
using System;
using System.Linq;
using System.Text;
    public class DuplicateView : IExternalCommand
            //Get UIdoc
            // Get doc
            try
                // pick view
               List<ElementId> ids = uidoc.Selection.GetElementIds().ToList(); //Replaced from PickObject
                if (ids.Count>0 )
                    View view = doc.GetElement(ids[0]) as View;
            catch (Exception e)
Hope this will Helps 🙂
Mohamed Arshad K
Software Developer (CAD & BIM)
