Find intersection point between curves using CPython3
SONA-ARCHITECTURE
SONA-ARCHITECTURE
Hi, with ItonPython2.7, I've got no error with this line declaration
results = clr.Reference[IntersectionResultArray]()
I can get my point coordinates
In CPython3, I try
results =  IntersectionResultArray()
setCompResult = curve1.Intersect(curve2, results)
I've got no error but result is empty
Do you know why?
I saw this for Rhino but does not work for me...
https://discourse.pyrevitlabs.io/t/pyrevit-cpython-python-3-equivalent-of-the-ironpython-python-2-im...
Pierre NAVARRA
SONA-Architecture.
http://www.sona-architecture.com
https://fr.linkedin.com/in/pierre-navarra-62032a107
jeremy_tammik
No idea. Remember that this forum is for the Revit API, not for obscure Python related .NET wrapping issues. They will probably be answered better elsewhere. I would assume that you need some clr wrapper or conversion for CPython3 as well, just like you do for IronPython (or are you using ItonPython, as your question states? (Is that a typo?)).
SONA-ARCHITECTURE
Hi jeremy,
hope you fill fine!
Yes, sorry, I know that this is for Revit API C#, but I founded a post about this subject in Python and thought it was possible here..Sorry
I've got a client who asked me a Python script to get intersection point of two curves from grid and I can't get works the interesct function of curve with Cpython3...
Pierre NAVARRA
SONA-Architecture.
SONA-ARCHITECTURE
I found this : https://github.com/DynamoDS/Dynamo/wiki/Work-in-progress-to-improve-Python-3-support#parameters-usin...
Maybe it's not planed
Pierre NAVARRA
SONA-Architecture.
SONA-ARCHITECTURE
I founded the solution here : https://forum.dynamobim.com/t/bounding-box-at-grid-curve-intersections/95989/8?u=sona_architecture
So, the correct code is :
if pyEngineName == "ironpython":
            intersectResultArray = clr.Reference[IntersectionResultArray]()
            result = curve_1.Intersect(curve_2, intersectResultArray)
            if result == DB.SetComparisonResult.Overlap:
                interResult = intersectResultArray.Value
                point = interResult[0].XYZPoint
                DSpoint = point.ToPoint()
                intersection_points.append(DSpoint)
        else:
            intersectResultArray = IntersectionResultArray()
            result, intersectResultArray = curve_1.Intersect(curve_2, intersectResultArray)
                point = intersectResultArray[0].XYZPoint
Pierre NAVARRA
SONA-Architecture.
