Calling Revit command from chromium browser.
Andrej.Licanin
Andrej.Licanin
This is another guide on chromium browser using cef sharp. Hope some one finds it usefull.
This is a continuation of this post : Solved: Simple WPF with a chromium browser guide - Autodesk Community - Revit Products
Basicly what I wanted was for a button in the browser (on a webpage) to trigger a command in revit. This works by "binding" a javascript method to a c# object and its method. In the Javascript we await for the object and call its function.
So lets make a dummy object for binding and a method in it. In order to call a Revit method it will need a reference to an external event handler and its event.
   public class BoundObject
       public int Add(int a, int b)
           ExtApp.handler.a = a;
           ExtApp.handler.b = b;
           ExtApp.testEvent.Raise();
           return a+b;
The event and its handler are saved in the External app as static for ease of access.
  internal class ExtApp : IExternalApplication
      public static IExternalApplication MyApp;
      public static ChromiumWebBrowser browser;
      public static ExternalEvent testEvent;
      public static MyEvent handler;
      public Result OnShutdown(UIControlledApplication application)
         // Cef.Shutdown();
          return Result.Succeeded;
      public Result OnStartup(UIControlledApplication application)
          MyApp = this;
          //code for making a button
          handler = new MyEvent();
          testEvent= ExternalEvent.Create(handler);
In the wpf the browser is embeded like this
<Window x:Class="RevitTestProject.TestWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006"
        xmlns:d="http://schemas.microsoft.com/expression/blend/2008"
        xmlns:local="clr-namespace:RevitTestProject"
        xmlns:cef="clr-namespace:CefSharp.Wpf;assembly=CefSharp.Wpf"
        mc:Ignorable="d"
        Width="1000" Height="500">
    <Grid Background="PapayaWhip">
        <cef:ChromiumWebBrowser Name="ChromiumBrowser" Address="http://www.google.com" Width="900" Height="450"  />
    </Grid>
</Window>
and the code behind  of the window is :
        public TestWindow()
            InitializeComponent();
            ChromiumBrowser.Address = "https://www.google.com";
            ChromiumBrowser.Address = "C:\\Users\\XXX\\Desktop\\index.html";
            BoundObject bo = new BoundObject();
            ChromiumBrowser.JavascriptObjectRepository.Register("boundAsync", bo, true, BindingOptions.DefaultBinder);
        public void Dispose()
            this.Dispose();
So to use it make an index.html and make the path to it in the browser address.
 The Test webpage look like this:
<html>
<head>
    <title>Bridge Test</title>
    <!-- <script src="script.js"></script> -->
    <script type="text/javascript">
     async function callCSharpAction() {
        await CefSharp.BindObjectAsync("boundAsync");
        boundAsync.add(16, 2);
    </script>
</head>
<body>
    <button id="action1" onclick="callCSharpAction()">Action 1</button>
    <button id="action2" onclick="alert('Button is working')">Action 2</button>
    <button id="action3">Action 3</button>
</body>
</html>
The handler code:
  internal class MyEvent : IExternalEventHandler
      public int a;
      public int b;
      public void Execute(UIApplication app)
          TaskDialog.Show("yoyoy", "data is "+a.ToString()+" and "+b.ToString()+".");
      public string GetName()
          return "YOYOOY";
jeremy_tammik
Thank you very much indeed for a very nice example of implementing a minimal external event and using it to call Revit from outside, from a modeless context. This is a perfect fit for The Building Coder topic group:
I'll gladly add it to the blog next week, if I may. Happy weekend to you!
Andrej.Licanin
Sure Jeremy, id love to see what people can do with it 🙂
Andrej.Licanin
To make a callback from c# function to the browser, you just need an instance of the browser, and a function in the javascript code that will be called.
here is an edited index.html
<html>
<head>
    function showAlert(arg1) {
        // Your JavaScript logic here
        alert("Function called with arguments: " + arg1);
        return ;
    </script>
</head>
<body>
</body>
</html>
and in our bound class we save a instance to the browser so we can use it on command
        public int aS;
        public int bS;
        internal ChromiumWebBrowser browser;
        public void CallCSharpMethod()
            MessageBox.Show("C# method called!");
            // Add more code here as needed
            return a+b;
        public int SendSomeDataFromLocal(int a)
            browser.ExecuteScriptAsync("showAlert("+a.ToString()+")");
            return a;
i passed it when i created the browser in the window codebehind.
public TestWindow()
    //ExtApp.boundObj = bo;
    bo.browser = ChromiumBrowser;
finally you can call it from revit
   public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
       ExtApp.boundObj.SendSomeDataFromLocal(999);
this concludes a round trip from the browser and back. I hope anyone reading this finds it usefull.
