Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Duplicate FloorType
2 REPLIES 2
724 Views, 2 Replies
Duplicate FloorType
Hi All,
I was trying to duplicate floor types with code below. It looks working but for some reason it's not reflected on Revit Type Selector. I tested it with dynamo and the new type is showing there..Something am i missing? Thanks.
                    FloorType floorType = new FilteredElementCollector(doc)
                    .OfClass(typeof(FloorType))
                    .WhereElementIsElementType()
                    .Cast<FloorType>()
                    .Last();
                    Element newType = floorType.Duplicate("SAMPLE TYPE");
                    doc.Regenerate();
2 REPLIES 2
recepagah12
I tested the same code in Revit 2020 and it worked. Did you write this code in open transaction? Also, you don't need to regenerate the document. Also, don't forget the test if the floor type is null or not. If you have any further question don't hesitate to ask?
I hope this helps,
Recep.
Tags (2)
in reply to: recepagah12
yeah it works after i restart mu revit. Cheers!
Forma Design Contest
Rail Community
