DuctInsulationType
DuctInsulationType
jainn
DuctInsulationType
jainn
Hi all,
How to create DuctInsulation Programatically, if document does not contains any default DuctInsulationType/DuctInsulation.
Below Method require DuctInsulationTypeID to create Insulation
DuctInsulation.Create(doc, ductType.Id, DuctInsulationType.Id, Thickness)
Document screen shot attach for reference
Please suggest.
Revitalizer
you could use ElementTransformUtils.CopyElement to copy DuctInsulation or DuctInsulationType from another Revit file to your target project file.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
jainn
Thanks for your Reply.
I tried your suggestion but get stuck in passing ElementID(elementToCopy).
ElementTransformUtils.CopyElement(Document document, ElementId elementToCopy, XYZ translation);
from where we can get these value.
As my document does not contains any default DuctInsulationType/DuctInsulation...
please suggest.
Revitalizer
you have to try out which CopyElement overload fits, there are some samples just in this Revit API forum.
Also, you must use this method the right way:
Prepare a source file which contains your Element or Type.
If you have your Element, it has a Type automatically.
You need to populate this "template" file manually.
After this, copy this known (!) Element into your empty target project file.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
