Applying Material to solid
sobon.konrad
sobon.konrad
I have been looking all over (Jeremy's blog, SDK Samples, google etc) to find an answer to this question. I remember seeing an example on Jeremy's blog where he was able to add a material to geometry face. Now, in Revit 2016 a Face doesn't have that optin anymore. I believe Jeremy's example was in Revit 2009. Anyways, I am looking for confirmation that there is/is not a way to add/apply a material to a face of a solid, or entire solid at once. If I don't have to loop through all faces then i would like to avoid that.
Is Paint() the only way to add Material to a solid that already exists?
Is GeometryUtils and all of the Solid creation overloads the only way to apply material to a solid? Is it only possible on creation? Can it be done afterwards?
Thanks!
rosalesduquej
Hi Konrad,
I saw a similar post to applying materials with the Revit API. In one part of the post, one of our forum contributors suggested to use FreeFormElement Class.
"since you are in Family context, you could use FreeFormElements, based on your Solids. Once created such a FreeFormElement, you can assign a subcategory, add FamilyParameters and so on."
Here is the link to the Forum post. https://forums.autodesk.com/t5/revit-api/applying-a-material-to-a-directshape/td-p/5745839
And as far as I know, you are correct with Paint() being the way to add the material to an existing solid.
Here is more information about it. http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-BE4672C9-E8BB-4157-8A2C-9067113FC55E
Hope this helps to clarify your question.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
sobon.konrad
Jaime,
Thank you for the answer. I will test both methods and report any results. However, can we make this an official user request? Ability to add material to solids after its creation or even better, ability to specify material for DirectShape GeometryObjects. Either would have been highly desired in the context of what I am working on.
Thank you,
Revitalizer
Hello Jaime,
in addition to Konrad's reply,
it would be fine if we could drive the Materials of a DirectShape or its faces by FamilyParameters.
Best regards,
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
rosalesduquej
Hi Konrad & Revitalizer,
I found another forum post where similar functionality gets asked.
http://forums.autodesk.com/t5/revit-api/visible-and-material-parameters-of-a-directshape-in-a-family...
I also found the Wishlist request in our system and I have added both of your comments to get the ball rolling.
The wishlist record is CF-3073 for your record.
Jaime Rosales D.
Ning_Zhou
hi Jaime, how to use Paint() to add the material to an existing solid?
http://forums.autodesk.com/t5/revit-api-forum/assign-material-to-directshape-via-paint/td-p/6709367
