Hello everyone,
I have to draw different colored, filled circles via the Revit API. Does anyone know how to do this?
I managed to create unfilled circles, but I can only change the color of all Circles. So all of my circles alway have the same color.
Thank you in advance for your help.
Solved by BenoitE&A. Go to Solution.
Hey,
Have you tried to create a FilledRegion ?
Syntax is FilledRegion.Create() and you can use as an input a CurveLoop, so you can put a Circle in the CurveLoop.
https://www.revitapidocs.com/2020/290f529f-2bc0-fda3-d2ff-7b7e2ef7e29f.htm
Thanks for your suggestion.
I managed creating a circle with a pattern.
But I'm still unable to change the color.
Also I have changed the filling pattern, but I cant change it to the Pattern "<Solid fill>".
Below I've added my code.
public void drawCircle(Document doc, XYZ center, double radius) { FilteredElementCollector fillRegionTypes= new FilteredElementCollector(doc).OfClass(typeof(FilledRegionType)); foreach (FilledRegionType frt in fillRegionTypes) { List<CurveLoop> profileloops = new List<CurveLoop>(); double xMax = center.X + radius; double xMin = center.X - radius;
double step = Math.PI/8; List<XYZ> pointList = new List<XYZ>(); for (double phi = 0; phi <= (2*Math.PI); phi = phi + step) { double x1 = center.X + radius * Math.Cos(phi); double y1 = center.Y + radius*Math.Sin(phi); pointList.Add(new XYZ(x1, y1, 0)); } pointList.Add(new XYZ(center.X + radius * Math.Cos(0), center.Y + radius*Math.Sin(0), 0)); CurveLoop profileloop = new CurveLoop(); XYZ successor = null; foreach (XYZ point in pointList) { if (successor != null && point != null) { Line line = Line.CreateBound(successor, point); profileloop.Append(line); } successor = point; } profileloops.Add(profileloop); ElementId activeViewId = doc.ActiveView.Id; using (Transaction transaction = new Transaction(doc)) { if (transaction.Start("Create filled region") == TransactionStatus.Started) { FilledRegion filledRegion1 = FilledRegion.Create(doc, frt.Id, activeViewId, profileloops); transaction.Commit(); } } break; } }
Hey,
I guess you will have to find the Type of your FilledRegion and modify it.
FilledRegion fr;
FilledRegionType type = myDoc.GetElement(fr.GetTypeId()) as FilledRegionType;
type.FillPatternId = myNewFilledRegionPattern.Id;
type.Color = myNewColor.Id;
Again to find the FilledRegionType you will have to filter the model using something looking like this
FilteredElementCollector col = new FilteredElementCollector(myDoc)
Same for Pattern, Color, etc...
Many thanks for the help. I finally made it. Below, I added my code.
Revit Update has changed the methods a bit. But now everything is working.
using (Transaction transaction = new Transaction(doc)) { if (transaction.Start("Create filled region") == TransactionStatus.Started) { filledRegion1 = FilledRegion.Create(doc, frt.Id, activeViewId, profileloops); FilledRegionType type = doc.GetElement(filledRegion1.GetTypeId()) as FilledRegionType; Color green = new Color(0, 250, 0); type.ForegroundPatternColor = green; FillPatternElement myFillPattern = new FilteredElementCollector(doc).OfClass(typeof(FillPatternElement)).Cast<FillPatternElement> ().First(a => a.Name.Contains("Solid fill")); type.ForegroundPatternId = myFillPattern.Id; transaction.Commit(); } }
