Macro into a NewAddInId
I am trying to turn my macro into an "External Tools" Addin button but while adding the code to implement the IExternalCommand and I am doing something wrong. Below colored red are my errors in visual studio. Any help would be greatly appreciated.
namespace AlignViews
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    public partial class ThisDocument : IExternalCommand
        static AddInId appId = new AddInId(new System.Guid("7BD4FE06-702E-4A54-88B0-A70EFD65F60B")
        public void Result Execute(ExternalCommandData commandData, ref string message, ElementSet elementSet)
            // Get the current document
            Document curDoc = this.Application.ActiveUIDocument.Document;
j.buijs
What do the errors say? This snippet of code looks good to me.
stever66
In Visual Studio, have you added the references to RevitAPI.dll and and the RevitUIAPI.dll?  (I may have the exact names wrong.)
And have you added the typical "using" statements?
jeremytammik
Dear Simon,
The code looks OK to me too.
I would suggest you work through the Revit API getting started material and create a new add-in from scratch first:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Once you have that up and running, you will understand all the basic concepts and it will be easier for you to migrate the existing macro.
Best regards, good luck, and have fun,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
