Double wall problem with door opening also in API
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Is it bug or I doing something wrong??
if I create wall and insert door.
Then I create other wall paralel with bottom offset and then I join two wall together the opening for door it doesn't create throug both walls.
It work only if I create paralel wall with bottom offset 0 and then join two wall and then change parameter of the bottom offset wall.
thx
