Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Document is "null".
3 REPLIES 3
oguzkomcu
421 Views, 3 Replies
Document is "null".
I want it to work in the codes I want with Revit opened. " using (var collector = new FilteredElementCollector(doc))" in this line goes into a loop after the code. It also does this in my other "doc" requested codes. As a result, the codes I want do not work. Is it because of "doc = null" or is there a different problem?
Labels (2)
3 REPLIES 3
naveen.kumar.t
in reply to: oguzkomcu
Hi @oguzkomcu ,
Please take a look at the below link
https://forums.autodesk.com/t5/revit-api-forum/how-to-get-uiapplication-from-iexternalapplication/td...
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
oguzkomcu
I fixed the document error but my loop error continues. When I want "ActiveView", I run the method again, come to the uiapp.OpenAndActivateDocument method, return to the beginning of the method and loop it. What is the reason of this ?
Error checking helps figure these issues out. Have you tried using a Try{} Catch{}(ex Exception) to see what Revit tells you when you attempt to get the active view? Have you tried getting the active view using Document.ActiveView()?
Rail Community
