How to get UIApplication from IExternalApplication
cedemax
cedemax
Hi!
Following this post i tried to implement it  in an External Application as they suggested. However i don't understand how i can get the UIApplication from the UIControllApplication. After some googling this seems impossible, instead one is supposed to get it from the "object sender" in the PanelEvent class. When debugging the code it shows PanelEvent class object sender type to be RvtRibbonTab, which when cast to Application returns null and cant thus be used to create an UIApplication. What am I missing?
Mustafa.Salaheldin
You should use the idle event.
Try the following code and if it satisfies your needs don't forget to mark the rply as an answer:
#region Namespaces
using System;
using System.Text;
using System.Linq;
using System.Xml;
using System.Reflection;
using System.ComponentModel;
using System.Collections;
using System.Collections.Generic;
using System.Windows;
using System.Windows.Media.Imaging;
using System.Windows.Forms;
using System.IO;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Events;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Structure;
using Autodesk.Revit.DB.Mechanical;
using Autodesk.Revit.DB.Electrical;
using Autodesk.Revit.DB.Plumbing;
using Autodesk.Revit.UI;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.UI.Events;
//using Autodesk.Revit.Collections;
using Autodesk.Revit.Exceptions;
using Autodesk.Revit.Utility;
using RvtApplication = Autodesk.Revit.ApplicationServices.Application;
using RvtDocument = Autodesk.Revit.DB.Document;
#endregion
namespace RevitAddinCS2
    [Transaction(TransactionMode.Manual)]
    [Regeneration(RegenerationOption.Manual)]
    public class ExtApp : IExternalApplication
        #region Cached Variables
        public static UIControlledApplication _cachedUiCtrApp;
        #endregion
        #region IExternalApplication Members
        public Result OnStartup(UIControlledApplication uiCtrlApp)
            _cachedUiCtrApp = uiCtrlApp;
            try
                //TODO: add you code below.
                _cachedUiCtrApp.Idling += OnIdling;
                return Result.Succeeded;
            catch (Exception ex)
                MessageBox.Show( ex.ToString() );
                return Result.Failed;
        private void OnIdling(object sender, IdlingEventArgs e)
            _cachedUiCtrApp.Idling -= OnIdling;
            UIApplication uiapp = sender as UIApplication;
            if (uiapp != null)
                UIDocument uidoc = uiapp.ActiveUIDocument;
                Document doc = uidoc.Document;
        public Result OnShutdown(UIControlledApplication uiApp)
            try
                MessageBox.Show(ex.ToString());
        #endregion
¯\_(ツ)_/¯
Let it work like a charm.
Mustafa Salaheldin
Digital Integration Manager, DuPod
Facebook | Twitter | LinkedIn
cedemax
Thank you! This was exactly what i wanted. I added the UIApplication as another cached variable in order to access it from the other event. Thank you again!
Can you do this for the Failure Handling Event?  I keep getting a null reference for the uiapp when trying to get this from the Failure Handling event.  When debugging the sender appears to be an ApplicationServices.Application object.
void ControlledApplication_FailuresProcessing(object sender, Autodesk.Revit.DB.Events.FailuresProcessingEventArgs e)
            List<ElementId> oFailedElements = new List<ElementId>();
            //My Failure Handling Code is here.
Chuong.Ho
Try some :
 public Result OnStartup(UIControlledApplication application)
        application.ControlledApplication.ApplicationInitialized  += test;
    private void test(object sender, ApplicationInitializedEventArgs e)
        if (sender is Application application)
            var uiApp = new UIApplication(application);
            // something
Chuong Ho
ricaun
Actually you can access the internal UIApplication inside the UIControlledApplication using some reflation. So you don't need to wait for the event.
    UIApplication uiapp = application.GetUIApplication();
    string userName = uiapp.Application.Username;
Here is the extension code.
/// <summary>
/// Get <see cref="Autodesk.Revit.UI.UIApplication"/> using the <paramref name="application"/>
/// </summary>
/// <param name="application">Revit UIApplication</param>
public static UIApplication GetUIApplication(this UIControlledApplication application)
    var type = typeof(UIControlledApplication);
    var propertie = type.GetFields(BindingFlags.Instance | BindingFlags.NonPublic)
        .FirstOrDefault(e => e.FieldType == typeof(UIApplication));
    return propertie?.GetValue(application) as UIApplication;
You can find the whole file extension below with the extension to convert UIApplication to UIControlledApplication as well.
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Chuong.Ho
@ricaun , that is awesome solution.
Chuong Ho
