distribution list with API
Erich.Kallenda
Erich.Kallenda
How can I use API to control whether names need to be updated in a distribution list?
jeremy_tammik
Is this list a BIM schedule? If so, doesn't it update automatically whenever the model changes? This is a BIM, and everything ought to be connected.
Erich.Kallenda
This is a Parameter in the Panel Shedules, and changes you must make manually.
When in project are 50 panel shedules it ist many time you need to control.
Erich.Kallenda
When you have changes, you mast go into the list, and take the button "Update Names"
jeremy_tammik
Aha. Well, in that case, if it is so simple, this process can be easily automated as follows, with no programming and no API usage required, using a journal file:
Assuming you have a number N of files. You wish to open file 1, 2, 3, ... N, display the form that you show in your screen snapshot. click Update Names, close the form, save the file, close the file.
In that case, automate it like this, more or less:
  • Launch Revit.exe
  • Open file 1
  • Display the form
  • Click Update Names
  • Close the form
  • Save the file
  • Close the file
  • Shut down Revit
Now go and find the journal file that was generated by that process.
You can use this journal file to perform the same actions in each of the other files.
Yes, you need to start Revit and shut it down every time for every file, so it is a slow process. Who cares, it is automatic.
Here are two examples of using this technique in practice (15 years ago!):
Vitaly_Demur
Hello Jeremy,
Thank you very much for your response and the direction we should look into.
I am Erich's colleague and have asked him to improve the program's weakness. In the Revit distribution lists, there is only one way to change the elements or the description of the circuit. The 'Circuit Description' is automatically generated from the parameters of the circuit [Load Classification] and [Space Name-Number].
When I move the element to another room, Revit does not update it automatically - you have to manually click into the cell first, and then the 'Update Name' button becomes available, which you can click. (Gelöst: Electrical Circuits - Update Names - Autodesk Community)
We want to achieve with the programming that the user is first shown the list of changed distributors (i.e., elements that have been moved to another room), and the user can then decide which distributor to update. Erich has started to create a logic and is first looking for this function in the API.
Could you please show us the direction again based on the new findings?
I have looked at the journal file and found the following commands.
Jrn.PushButton "ToolBar , {}{} , Dialog_BuildingSystems_PanelScheduleCircuitDlgbar" _
, "Update Names, Control_BuildingSystems_CircuitsUpdateNames"
' 0:< Unnecessary nesting;ACommandRouter_2;-1;ID_PANELSCHEDULE_CIRCUITS_UPDATENAMES ;N++EB(NB);
Thank you in advance!
Vitaly
rcrdzmmrmnn
I would also go the same way as the link you posted above. You don't need to automate clicking the "Update Names" if you can replicate it's function yourself. I think a pseudocode would look like this:
foreach circuit in circuits
     originalLoadName = circuit.LoadName
     potentialNewName = ""
     elementsFromCircuit = circuit.Elements
     foreach element in elementsFromCircuit
           elementSpaceName = element.Space.Name
           elementSpaceNumber = element.Space.Number
           potentialNewName+=$"{elementSpaceName} {elementSpaceNumber},"
     if(originalLoadName ==potentialNewName)
          print("no elements were moved")
     else
          #add circuit to a list of changed circuits to further analysis
I mean, there are nuances, like, if only one space is found, the Load Name will be [Load Type] [SpaceName] [Space Number], and if there is more than one, the name will be [Load Type] [SpaceNumber1] [Space Number2] [Space NumberX]
but I think it's way more convenient than to work with PostCommand and JournalFiles etc...
