Reference lines driven by reference points in Revit Family Adaptive
Davide_Barbiero2DLH4
Observer Observer
Observer
Observer
Hi, I’m working on a GH script with Rhino.Inside to create some driving axis inside a Revit Adaptive Family. Those axis have to be Revit Reference Lines, that are driven by Revit Reference Points Adaptive. I was able to create those points with the code, but I can not figure out how to create the lines with the code so that they are connected with the points and driven by them.
Basically what I want to achieve with Python or C#, is to create branches in order to have couples of points (start, end points), and then to create a Revit Reference Lines from that input list. Below an example of the reference line.
Observer
Observer
Attached you can find the Python code block.
Observer
Observer
Below is another code with C# that I've tried but it is not working:
#r "C:\Program Files\Autodesk\Revit 2023\RevitAPI.dll"
#r "C:\Program Files\Autodesk\Revit 2023\RevitAPIUI.dll"
using System;
using System.Collections.Generic;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
public class CreateReferenceLines : IExternalCommand
    // Input: Branched list of reference points (provided via Rhino Inside Revit)
    public List<List<ReferencePoint>> ReferencePointBranches { get; set; }
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        UIApplication uiApp = commandData.Application;
        Document doc = uiApp.ActiveUIDocument.Document;
        // Validate input
        if (ReferencePointBranches == null || ReferencePointBranches.Count == 0)
            message = "No reference points provided.";
            return Result.Failed;
        foreach (var branch in ReferencePointBranches)
            if (branch.Count != 2)
                message = "Each branch must contain exactly 2 ReferencePoints.";
        using (Transaction t = new Transaction(doc, "Create Reference Lines"))
            t.Start();
            try
                // Iterate over branches and create reference lines
                    ReferencePoint point1 = branch[0];
                    ReferencePoint point2 = branch[1];
                    CreateReferenceLine(doc, point1, point2);
                t.Commit();
                TaskDialog.Show("Success", "Reference lines created successfully.");
            catch (Exception ex)
                t.RollBack();
                TaskDialog.Show("Error", $"An error occurred: {ex.Message}");
        return Result.Succeeded;
    /// <summary>
    /// Creates a reference line between two reference points.
    /// </summary>
    private void CreateReferenceLine(Document doc, ReferencePoint point1, ReferencePoint point2)
        // Create a ReferencePointArray
        ReferencePointArray referencePointArray = new ReferencePointArray();
        referencePointArray.Append(point1);
        referencePointArray.Append(point2);
        // Create the reference line
        CurveByPoints curve = doc.FamilyCreate.NewCurveByPoints(referencePointArray);
        curve.IsReferenceLine = true; // Mark the curve as a reference line
