Disable IUpdater in Family Document
rvtquestions
rvtquestions
While implementing background applications using IUpdater I want to ensure it is only functioning in Project Documents and not Family Documents. I assume they will still load up when opening up a family, for instance. If that is the case, what are some ways to ensure my IUpdater is registered and functioning only when in a Project Document?
Can I check during the public Result OnStartUp() level
(How can I get Document doc at this level without ExternalCommandData?)
if(doc.IsFamilyDocument) { } else { UpdaterRegistry.RegisterUpdater(updater); rest of code }
Or do I have to test it at the public void Execute(UpdaterData data) level?:
Document doc = data.GetDocument();
if (doc.IsFamilyDocument)
else
continue with rest of code
Are these methods viable or is there a better way?
FaustoMendezcom
Just use the Application Initialized Events
like
public class DocumentOpenedEventArgs : RevitAPIPostDocEventArgs
and or
public class DocumentOpeningEventArgs : RevitAPIPreEventArgs
like
public void application_DocumentOpened(object sender, DocumentOpenedEventArgs args)
// get document from event args.
Document doc = args.Document;
http://www.revitapidocs.com/2018.1/1c21b33d-1314-d096-0a36-ad59ad80c6e9.htm
Hope it helps 🙂
www.faustomendez.com
jeremytammik
Look at the description of the DistanceToSurfaces SDK sample:
https://thebuildingcoder.typepad.com/blog/2010/04/element-level-events.html#3
It says:
  • On start-up, register a DocumentOpened event. When a document is opened:
  • Check for the presence of the sphere family.
  • Check for the presence of a 3D view named 'AVF'.
  • Create a GetChangeTypeGeometry trigger that will activate when a wall, mass, or family instance changes.
You could use a similar approach, checking whether the current document is a family document or not and not registering any trigger at all in the former case.
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
